On 14 Nov 2005 15:21:19 -0800, "Robert M. Gary"
wrote: I"m sure the help file will help, I just haven't gotten there yet. I set the FIR but didn't recognize the area because it didn't show me airport names (just airspace). Again, I'm sure if I sit down with the documentation I can get it to work. I use Flightsoft now for planning and it works a bit more out-of-the-box, but may or may not be better. -Robert You really need to read the help file! If you've set the FIR's have you downloaded the data from the internet? i.e. Map (at each zoom level unless you register), Nav, Elevation? That's how it's updated! As for the PDA simply 'synchronise CE device' from the icon, via the PDA cradle using Active Sync. This prog has so many options you can't expect it to just work without reading the basic help info. Lots of icons on the top & side of the screen to select/deselect options. The first thing to do is right click the mouse and 'search' for your nearest airfield then click 'Plane Pos'. That puts the plane at the centre of the screen in your area. If you don't the plane position could well be in the sea or another FIR anywhere in the world. You also need to check properties and ensure you set the 'Limit PocketPC Memory storage to' xxx MB |
On Mon, 14 Nov 2005 19:15:20 -0600, Darrel Toepfer
wrote: wrote: Robert M. Gary" wrote: I"m sure the help file will help, I just haven't gotten there yet. I set the FIR but didn't recognize the area because it didn't show me airport names (just airspace). Again, I'm sure if I sit down with the documentation I can get it to work. I use Flightsoft now for planning and it works a bit more out-of-the-box, but may or may not be better. You really need to read the help file! Download all the data files, it takes awhile. And also that you have a compatible GPS. PocketFMS doesn't work with my Garmin GPS III. Works great with my Magellan 315... I had a lot of trouble with an old Trimble Flightmate Pro (1993 database) but eventually got it to work. As long as you can get NMEA sentences, at the right baud rate, with the right parameters selected it should work. |
Flight Planning Software | Chris G. | Piloting | 22 | July 4th 05 06:33 PM |
[!] Russian Arms software sale | Naval Aviation | 0 | December 18th 04 05:51 PM | |
Free Flight Planning Software | Dean Wilkinson | Piloting | 20 | September 25th 04 03:38 AM |
Free Flight Planning Software | Dean Wilkinson | Products | 0 | September 18th 04 10:44 PM |
Next: Aviation Map software | Toks Desalu | Piloting | 5 | May 24th 04 07:55 PM |
