More grist for the battle of the battery
Old November 15th 05, 11:27 AM
Vaughn
Default More grist for the battle of the battery
"Don Johnstone" wrote in
message ...
At 02:12 15 November 2005, Marc Ramsey wrote:
There is a cure for that, a fuse.
True, but there is no fuse that can protect from an internal short circuit.
Any type of battery can (at least rarely) do this. I have seen both lead acid
and NIMH batteries burn up this way. (It the case of the NIMH it was an irate
firefighter whose portable radio had nearly caught fire.) Naturally, the more
energy in the cell, the more heat, smoke, and (possibly) flames you can expect.
Lithium batteries have a very high energy density and the innards love to burn,
so internal shorts are a particular concern with them.
How great is the danger as a practical matter? That is the true question
here!
Vaughn
Old November 15th 05, 05:25 PM posted to rec.aviation.soaring
message ...
here!
Indeed; however, there are a jillion laptop batteries in use, but very
few problems (I haven't heard of any, but there must be some). For
glider use, I'd want to know what the usable temperature range is (some
units specify only up to 95 deg. F), what altitude they can be used to
(haven't seen any specifications for that), and what safety features are
built into them (fuses, both for amps and overheating, might be
standard, and welcome, features, for example).
Eric Greenwell
Washington State
USA
Battery Question [email protected] Soaring 19 September 15th 05 01:38 AM
60 years from Battle of Tali-Ihantala June-July 1944 - which decidedthe fate of Finland Jukka O. Kauppinen Military Aviation 1 June 29th 04 03:00 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
