![]() "Steven P. McNicoll" wrote in message nk.net... "Marco Leon" mmleon(at)yahoo.com wrote in message ... Have you ever read either TSO-c146a or TSO-c129? One of the requirements specifies that the database in an IFR-certified box adhere to a higher tolerance of corruptibility. Are you sure the VFR portable's database was built to the same specifications? If not--higher risk. How so? If you really don't see the increased risk in using a database that is not safeguarded from being corrupted to a level that another one that is, then your ability to comprehend the subject matter at hand is far below the rest of the thread's participants. It would be useless to explain the other requirements of the TSO to you because you obviously would not understand any of the concepts. I can go on and list each item-by-item but you seem to be literate so you can read the TSOs at your leisure. Bottom line is as I stated in my previous post that you don't personally believe the requirements outlined in these documents reduce risk in any way, shape, or form. If that's the case, I'm glad you don't help the FAA develop these standards. If you believe there is a higher risk I think you should be able to identify that risk. You're trolling. |
![]() "Marco Leon" mmleon(at)yahoo.com wrote in message ... If you really don't see the increased risk in using a database that is not safeguarded from being corrupted to a level that another one that is, then your ability to comprehend the subject matter at hand is far below the rest of the thread's participants. It would be useless to explain the other requirements of the TSO to you because you obviously would not understand any of the concepts. I can understand anything you can explain. Do you think you can explain the hazard in the use of a handheld GPS during IFR enroute flight in US controlled airspace? Nobody else could. You're trolling. You bet I am. I'm trolling for someone, anyone, that can identify any risk in the use of a handheld GPS during IFR enroute flight in US controlled airspace. I've been doing that for several years without even a nibble. |
