Gear Warning
Old November 16th 05, 04:08 PM posted to rec.aviation.soaring
Default Gear Warning
I would recommend magnetic reed switches (~$0.50) instead of microswitches.
Reed switches require no contact with the spoiler and gear controls since
they operate in proximity to a tiny magnet epoxied to a control rod. They
don't need precise adjustment to work and they never wear out.
I selected a raucous low pitched buzzer as the warning horn because it
didn't sound like any other device in the cockpit. High pitched squealers
sound too much like an audio vario.
Another neat backup is GPS_LOG WinCE PDA software. It sounds a warning of
your choice by playing a .wav file when the glider descends to pattern
altitude above the terrain elevation map.
I use both systems.
Bill Daniels
"Nyal Williams" wrote in message
The wiring is not a complex problem; you just need
two paths for the current. One path when the gear
is up and another when the gear is down. It is better,
in my view, the bigger problem is finding a place to
put the switches. I tried to use a 9v batttery to
drive the system and quickly learned that when the
wings are off, nothing holds the spoiler handle in
place and the spoiler handle would open slightly in
the trailer and just run the battery down. Better
to wire it to the main battery and let the master switch
take care of this problem.
At 10:12 16 November 2005, Gadget Guy wrote:
Greetings all, I am looking for a drawing that depicts
the electrical
wiring of a DG-300. Does anyone know of a link or have
a basic drawing
of a gear warning system?
Thank you in advace
Gadget Guy
Old November 17th 05, 01:22 AM posted to rec.aviation.soaring
Hey Bill - You musta been the guy I saw flying down the ridge with the
gear down !
See ya, Dave
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
