![]() "Ron Garret" wrote in message ... Because if you hit terrain (you were aware that "cumulo granite" is a euphemism for terrain, yes?) you are unlikely to survive. And if you survive you are unlikely to escape serious injury. And your airplane is likely to be totaled as well. That to my mind qualifies as a hazard. Isn't that obvious? That's all true, but it's true of all flight. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is not going to cause a mountain to appear in front of you or wrest control of the aircraft away from you and dive it into the ground. |
IFR enroute navigation in US controlled airspace is not going to cause a mountain to appear in front of you Well, actually it could. Any navigation system which tells the pilot he is in one place when he is actually in another, which is used by a pilot who is in IMC, could cause the pilot to place himself in a position from which a collision with a mountainous surprise is unavoidable. While it is true that the navigation system did not move the mountain, the effect on the pilot is the same. I suppose the real risk of using^H^H^H^H^Hrelying on a VFR GPS is not one of collision (this is a risk inherent in any navigation system) but one of paperwork. If a pilot uses an IFR GPS and it misleads him into a mountain of granite (or sandstone, or shale), the dead pilot can claim that the fault does not lie with him. OTOH, if relying on a VFR GPS causes him meet the same fate, a mountain of paperwork sufficient to delay his appearances at the pearly gates will appear before him. It may be that a VFR GPS which is clipped to the right part of the yoke will provide better guidance in and among ridges than an IFR ADF. But there is a risk, not present with an IFR installation of anything, that the highly accurate VFR GPS unit will fall off the yoke at the wrong moment, perhaps while outside of radar coverage, or on an approach. There is a risk (present in VFR and IFR units) that the data displayed is incorrect - it has happened in our aircraft (Danbury moved four hundred miles without giving any notice to Ridgefield); IFR units are (presumably, though only the manufacturer really knows) tested to higher standards. There is a risk that the pilot will be unable to maintain the more challenging scan required by certain VFR GPS "installations" and thus will end up elsewhere than where he thought he was. Outside of a radar environment, in hostle terrain, this could activate the ELT. As for relying on controllers to "nudge" the aircraft back on course in a radar environment, this would be true primarily in airspace controlled by Steven P. McNicoll, who mever nakes mistakes. Merely human controllers might, for any number of reasons incomprehensible to Steven, miss something, allowing the pilot's error to terminate the flight prematurely. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message news ![]() Well, actually it could. Any navigation system which tells the pilot he is in one place when he is actually in another, which is used by a pilot who is in IMC, could cause the pilot to place himself in a position from which a collision with a mountainous surprise is unavoidable. While it is true that the navigation system did not move the mountain, the effect on the pilot is the same. The controller will alert the pilot to the navigational error. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is no more hazardous than being vectored. It may be that a VFR GPS which is clipped to the right part of the yoke will provide better guidance in and among ridges than an IFR ADF. But there is a risk, not present with an IFR installation of anything, that the highly accurate VFR GPS unit will fall off the yoke at the wrong moment, perhaps while outside of radar coverage, or on an approach. We're talking about enroute use, not approaches. If the aircraft is out of radar contact it will be routed via airways or within the usable limits of navaids. The pilot will be able to compare the GPS to his VOR or ADF to verify it's accuracy. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is no more hazardous than use of VOR along airways. There is a risk (present in VFR and IFR units) that the data displayed is incorrect - it has happened in our aircraft (Danbury moved four hundred miles without giving any notice to Ridgefield); IFR units are (presumably, though only the manufacturer really knows) tested to higher standards. There is a risk that the pilot will be unable to maintain the more challenging scan required by certain VFR GPS "installations" and thus will end up elsewhere than where he thought he was. Outside of a radar environment, in hostle terrain, this could activate the ELT. The controller will alert the pilot to the navigational error. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is no more hazardous than being vectored. If the aircraft is out of radar contact it will be routed via airways or within the usable limits of navaids. The pilot will be able to compare the GPS to his VOR or ADF to verify it's accuracy. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is no more hazardous than use of VOR along airways. As for relying on controllers to "nudge" the aircraft back on course in a radar environment, this would be true primarily in airspace controlled by Steven P. McNicoll, who mever nakes mistakes. Merely human controllers might, for any number of reasons incomprehensible to Steven, miss something, allowing the pilot's error to terminate the flight prematurely. It is not an option, it is required of all controllers. If you can't trust the controller to perform his job as he is required to do you cannot operate IFR in controlled airspace. |
I am talking about relying on a VFR GPS. You are talking about "using"
it, like using a tuna fish sandwich. In a situation where primary navigation instruments (e.g. VOR) are available to the pilot and his clearance, I see no problem =using= a VFR GPS. In a situation where radar vectors are being provided, I also see no problem =using= a VFR GPS. In a situation where radar vectors could be available, but are not being provided, one is relying on the controller to do something that the controller may not be doing. I assume that there is a little more monitoring of vectored aircraft than "own navigation" aircraft; the controller is depending on the pilot to navigate if a vector is not being provided. In a situation where radar coverage does not exist, and navigation is (therefore) via airways or within the usable limits of naviads, those navaids do no good if the pilot does not tune them in. This is the difference between =using= and =relying= on equipment which dominates so many of these threads. I see no problem using the standard navaids along with a VFR GPS. You probably agree here. I do see a problem using a VFR GPS and =not= using any other navaids in this situation; this is what I call "relying on" a VFR GPS. Your position on =this= is unclear because of the way you conflate the concepts "use" and "rely on" in your writing, and because of your statement The pilot will be able to compare the GPS to his VOR or ADF to verify it's accuracy. in support. (btw, it's "its") This tells me we're talking about two different things while pretending they are the same. The FAA does not prohibit the use of a VFR GPS or a tuna fish sandwich in IFR or IMC. It does prohibit relying on a VFR GPS, and it prohibits relying on a tuna fish sandwich in the same situation. Do you agree or disagree with the FAA's stance here? Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. I am talking about relying on a VFR GPS. You are talking about "using" it, like using a tuna fish sandwich. Start a new thread. This discussion is about the use of a handheld GPS for IFR enroute navigation in US controlled airspace. In a situation where radar vectors could be available, but are not being provided, one is relying on the controller to do something that the controller may not be doing. I assume that there is a little more monitoring of vectored aircraft than "own navigation" aircraft; the controller is depending on the pilot to navigate if a vector is not being provided. One is relying on the controller to do his job as he is required to do. The controller is required to provide radar monitoring and course guidance, if necessary, if the route is not on airways or within the usable limits of navaids. In a situation where radar coverage does not exist, and navigation is (therefore) via airways or within the usable limits of naviads, those navaids do no good if the pilot does not tune them in. Careful, you're approaching idiocy. This is the difference between =using= and =relying= on equipment which dominates so many of these threads. I see no problem using the standard navaids along with a VFR GPS. You probably agree here. I do see a problem using a VFR GPS and =not= using any other navaids in this situation; this is what I call "relying on" a VFR GPS. Your position on =this= is unclear because of the way you conflate the concepts "use" and "rely on" in your writing, and because of your statement The pilot will be able to compare the GPS to his VOR or ADF to verify it's accuracy. in support. (btw, it's "its") This tells me we're talking about two different things while pretending they are the same. No, we've been talking about use of handheld GPS for IFR enroute navigation in US controlled airspace. The FAA does not prohibit the use of a VFR GPS or a tuna fish sandwich in IFR or IMC. It does prohibit relying on a VFR GPS, and it prohibits relying on a tuna fish sandwich in the same situation. Do you agree or disagree with the FAA's stance here? Post the FAA's statement. I never suggested relying exclusively on VFR GPS, it was I that pointed out one is NOT relying exclusively on a VFR GPS when one is using a handheld GPS for IFR enroute navigation in US controlled airspace. |
it, like using a tuna fish sandwich. Start a new thread. This discussion is about the use of a handheld GPS for IFR enroute navigation in US controlled airspace. You sure you weren't a lawyer in a previous life? ![]() Careful, you're approaching idiocy. It was necessary. No, we've been talking about use of handheld GPS for IFR enroute navigation in US controlled airspace. [...] I never suggested relying exclusively on VFR GPS Ok. We are (and always have been) in agreement. But really... you do better than Clinton. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Jose wrote: I am talking about relying on a VFR GPS. You are talking about "using" it, like using a tuna fish sandwich. Start a new thread. This discussion is about the use of a handheld GPS for IFR enroute navigation in US controlled airspace. You sure you weren't a lawyer in a previous life? ![]() Careful, you're approaching idiocy. It was necessary. No, we've been talking about use of handheld GPS for IFR enroute navigation in US controlled airspace. [...] I never suggested relying exclusively on VFR GPS Ok. We are (and always have been) in agreement. Oh, Jose, you're giving up too easily! One of the (many) risks of UAHGPSFIFRENIUSCAS (you figure it out) is that a pilot might become complacent about using his primary navaids, particularly off-airways since the constant VOR twiddling required for off-airway navigation is such a pain in the ass and the use of the GPS is so effortless and (almost invariably) reliable. Yes, complacency is a form of incompetence. But that does make it any less of a risk. Pilot complacency, in all its many manifestations, is a widely recognized risk. Furthermore (and this is the important part) this particular form of complacency CANNOT MANIFEST ITSELF EXCEPT WHEN A HANDHELD GPS IS IN USE. That makes it reasonable to assign at least part of the causality to the use of the GPS. rg |
Jose wrote:
The FAA does not prohibit the use of a VFR GPS or a tuna fish sandwich in IFR or IMC. It does prohibit relying on a VFR GPS, and it prohibits relying on a tuna fish sandwich in the same situation. "N56789 cleared TUNA 36L" I think I heard that in a Hot Shots movie... -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "There are always alternatives." -- Star Trek: Spock, "The Galileo Seven" |
[the FAA] prohibits relying on a tuna fish sandwich in the same situation.
"N56789 cleared TUNA 36L" You can't fly a tuna fish approach unless you have a working ham sandwich as a backup. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
In article et,
"Steven P. McNicoll" wrote: "Ron Garret" wrote in message ... Because if you hit terrain (you were aware that "cumulo granite" is a euphemism for terrain, yes?) you are unlikely to survive. And if you survive you are unlikely to escape serious injury. And your airplane is likely to be totaled as well. That to my mind qualifies as a hazard. Isn't that obvious? That's all true, but it's true of all flight. The use of a handheld GPS for IFR enroute navigation in US controlled airspace is not going to cause a mountain to appear in front of you or wrest control of the aircraft away from you and dive it into the ground. And there are no other possible ways to hit terrain? rg |
