OK, Thinking-Cap Time...
Old November 17th 05, 10:47 PM posted to rec.aviation.owning
Default OK, Thinking-Cap Time...
Of course, we have a new squawk shortly after coming out of the shop.
Perhaps someone here can point me in the right direction?
Here's the scenario with our 1974 Piper Cherokee Pathfinder, with a 530
hour, normally aspirated Lycoming O-540-B4B5 engine:
1) Flying to Janesville, WI today. Extremely cold -- around 15 degrees
Fahrenheit on the surface, near zero at altitude. The first real cold snap
of the year.
2) In steady-state flight, both of us hear a "woo--woo--woo..." softly in
the headphones. It sounds just like strobes that aren't grounded properly.
3) The noise slows down -- or speeds up -- in synch with the prop RPM. At
2300 RPM, it's going a bit faster than once per second -- maybe around three
times every two seconds.
4) I switch our digital voltage/amperage meter to AMPs, and watch as it
oscillates in time with the noise. It's alternating from 5 amps to 10-11
amps, in time with the "woo--woo--woo"... Voltage appears to be pretty
steady at around 13.8-ish volts.
5) Adding load to the system (landing lights, fuel pump, etc.) makes the
noise louder. Adding load to the system and then suddenly turning
everything off makes the noise and amperage oscillation go away -- for about
30 seconds. It then returns.
6) Turning the alternator side of the split master switch ALSO makes the
noise go away. It sometimes stays away when I turn the alternator back on.
Sometimes it doesn't.
7) The battery is new this past summer.
So, we've got a noise and amperage indication that can be corrected by
adding load to the system -- and then suddenly taking it away. The noise
is also fixed -- sometimes -- by cycling the alternator off and on.
The service last week was having the impulse couplings serviced (per service
bulletin), so electrical things have been tinkered with since our last
flight. (This is ALWAYS when some new squawk seems to crop up.)
Any ideas? Loose ground wire somewhere? Alternator failing? Any and all
input is welcomed!
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 17th 05, 11:04 PM posted to rec.aviation.owning
Alternator problem. Possibly a filter, but my guess is a diode is going bad.
Alternator speed depends on engine speed.
Adding load makes the alternator work harder. Cutting it all out lets it loaf
until the battery charge drops a bit, then the alternator has to work again.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 17th 05, 11:32 PM posted to rec.aviation.owning
I'd say George is dead on. I also thought filter, but the fact that the
amps oscillate makes me think diode. I've never heard of a bad filter
causing an ammeter oscillation, the filters that have failed for me just
complain loudly.
Old November 17th 05, 11:39 PM posted to rec.aviation.owning
Could it be a very loose alternator belt ? The symptoms don't all jib
though.
Old November 18th 05, 01:00 AM posted to rec.aviation.owning
I third the thought. I have a capacitor filter across the output of the
alternator and ground. I have also cooked an alternator in the summer .
The fan on the back was not enough forced air for a high load when it is
hot. I added a blast tube form the front of the cowling to the "Blast
adapter" on the back on the Alternator. The hole in my cowling just
below the engine air intake is for the alternator. Works great. No more
over heating problems.
Michelle
going bad.
RPM. At 2300 RPM, it's going a bit faster than once per second --
maybe around three times every two seconds.
the noise louder. Adding load to the system and then suddenly
turning everything off makes the noise and amperage oscillation go
away -- for about 30 seconds. It then returns.
it loaf until the battery charge drops a bit, then the alternator has
to work again.
George Patterson
portable
radio.
Old November 19th 05, 04:00 PM posted to rec.aviation.owning
"George Patterson" wrote in message
news:Q%7ff.60$N44.3@trndny08...
snip
bad.
snip
Diodes are solid state devices which either work, are open (most common
failure), or are shorted out (less common failure). They don't suffer from
"going bad" or "getting weak". They either work or they don't. If they are
intermittant, it's a connection, not the diode itself.
DB
(Many years of Electronics experience)
Old November 20th 05, 12:02 AM posted to rec.aviation.owning
"Doodybutch" writes:
Well, maybe... I have had some larger power diodes whose *internal*
bonds would open when the diode got hot. When it cooled again, guess
what.
I also had a matrix of small-signal glass diodes that tested just
fine with an ohmmeter, but in operation.... turns out some would
"zener" when tested with the 12v that was used in the circuit.
But I really doubt that Jay's issue is alternator diodes....
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 17th 05, 11:58 PM posted to rec.aviation.owning
See: http://www.sacskyranch.com/altnoise.htm
Old November 18th 05, 03:29 AM posted to rec.aviation.owning
Awesome source -- thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 19th 05, 05:24 AM posted to rec.aviation.owning
And located just down the road from me!
Jack Allison
PP-ASEL-IA Student
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
FS9 Time Zone Files in BETA Test DDT Simulators 3 April 5th 04 06:06 PM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 06:44 AM
