OK, Thinking-Cap Time...
Old November 18th 05, 02:36 AM posted to rec.aviation.owning
Default OK, Thinking-Cap Time...
2) In steady-state flight, both of us hear a "woo--woo--woo..." softly in
the headphones. It sounds just like strobes that aren't grounded properly.
3) The noise slows down -- or speeds up -- in synch with the prop RPM. At
2300 RPM, it's going a bit faster than once per second -- maybe around three
times every two seconds.
4) I switch our digital voltage/amperage meter to AMPs, and watch as it
oscillates in time with the noise. It's alternating from 5 amps to 10-11
amps, in time with the "woo--woo--woo"... Voltage appears to be pretty
steady at around 13.8-ish volts.
Jay,
Is this not the "Cherokee oscillating Ammeter" thing? Mine has it. Exact
same symptoms. Had it for 11 years and 4 different alternators. Either
the split master switch (alternator side) or the alternator breaker
having a high resistance connection (either the wires or the
switch/breaker itself).
Google it. You should see lots of hits. A common problem if I recall.
Mike
Old November 18th 05, 03:33 AM posted to rec.aviation.owning
same symptoms. Had it for 11 years and 4 different alternators. Either the
split master switch (alternator side) or the alternator breaker having a
high resistance connection (either the wires or the switch/breaker
itself).
It may be -- but it just started happening in mine. *Something* had to
change, and the fact that my mechanic was digging around in the magnetos
last week seems to point to the all-to-common "mechanic-induced" squawk.
Or, it could be the sudden, severe cold? Or, it could be coincidence.
Next nice day I'm going to de-cowl the engine and tighten all electrical
connections. That has cured other electrical gremlins for us...and it's
cheap!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 18th 05, 04:56 AM posted to rec.aviation.owning
Jay - If you get desperate, you might be able to create this problem on
the ground using a hand held or jury rigged electric motor to spin the
alternator rather than having to run the engine. This would allow
better diagnostic capability using an oscilloscope.
However, if the problem only occurs only at higher amperage loads, a
fractional hp electric motor won't be able to spin the alternator.
Likewise the RPM may be a problem. Alternators spin pretty fast at
cruise - like over 10,000 rpm.
Old November 18th 05, 05:13 AM posted to rec.aviation.owning
If you try this, keep a fan blowing on the alternator. Even in cold
temperatures, it will need cooling air.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
Old November 18th 05, 12:25 PM posted to rec.aviation.owning
It's not just mechanics. Any good troubleshooter knows you always look
"where the human being was last".
__!__
Jay and Teresa Masino ___(_)___
http://www2.ari.net/jmasino ! ! !
http://www.OceanCityAirport.com
http://www.oc-Adolfos.com
Old November 18th 05, 03:36 PM posted to rec.aviation.owning
I would check all the grounds in the system. That can cause this
problem. Along with a bad alternator switch. It causes the VR to not
work properly. I had to bread each connection, clean it, then re-do it.
Regards, Ross
C-172F 180HP
KSWI
Jay Honeck wrote:
Of course, we have a new squawk shortly after coming out of the shop.
Perhaps someone here can point me in the right direction?
Here's the scenario with our 1974 Piper Cherokee Pathfinder, with a 530
hour, normally aspirated Lycoming O-540-B4B5 engine:
1) Flying to Janesville, WI today. Extremely cold -- around 15 degrees
Fahrenheit on the surface, near zero at altitude. The first real cold snap
of the year.
5) Adding load to the system (landing lights, fuel pump, etc.) makes the
noise louder. Adding load to the system and then suddenly turning
everything off makes the noise and amperage oscillation go away -- for about
30 seconds. It then returns.
6) Turning the alternator side of the split master switch ALSO makes the
noise go away. It sometimes stays away when I turn the alternator back on.
Sometimes it doesn't.
7) The battery is new this past summer.
So, we've got a noise and amperage indication that can be corrected by
adding load to the system -- and then suddenly taking it away. The noise
is also fixed -- sometimes -- by cycling the alternator off and on.
The service last week was having the impulse couplings serviced (per service
bulletin), so electrical things have been tinkered with since our last
flight. (This is ALWAYS when some new squawk seems to crop up.)
Any ideas? Loose ground wire somewhere? Alternator failing? Any and all
input is welcomed!
Thanks!
Old November 18th 05, 03:38 PM posted to rec.aviation.owning
OK, lets make that BREAK instead of bread.
Regards, Ross
C-172F 180HP
KSWI
Regards, Ross
C-172F 180HP
KSWI
530 hour, normally aspirated Lycoming O-540-B4B5 engine:
degrees Fahrenheit on the surface, near zero at altitude. The first
real cold snap of the year.
in the headphones. It sounds just like strobes that aren't grounded
properly.
RPM. At 2300 RPM, it's going a bit faster than once per second --
maybe around three times every two seconds.
it oscillates in time with the noise. It's alternating from 5 amps to
10-11 amps, in time with the "woo--woo--woo"... Voltage appears to
be pretty steady at around 13.8-ish volts.
the noise louder. Adding load to the system and then suddenly turning
about 30 seconds. It then returns.
the noise go away. It sometimes stays away when I turn the
alternator back on. Sometimes it doesn't.
noise is also fixed -- sometimes -- by cycling the alternator off and on.
service bulletin), so electrical things have been tinkered with since
our last flight. (This is ALWAYS when some new squawk seems to crop up.)
and all input is welcomed!
Thanks!
Old November 18th 05, 04:52 PM posted to rec.aviation.owning
So now we are breaking bread over our engines to fix problems?
Old November 18th 05, 07:16 PM posted to rec.aviation.owning
Dang, I should have read it before I published this....
Regards, Ross
C-172F 180HP
KSWI
Old November 18th 05, 03:57 PM posted to rec.aviation.owning
Does it go away when you turn off the beacon?
Ammeter swings and a similar noise in my plane are due to the beacon's
flasher.
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
FS9 Time Zone Files in BETA Test DDT Simulators 3 April 5th 04 06:06 PM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 06:44 AM
