OK, Thinking-Cap Time...
Old November 18th 05, 04:56 AM posted to rec.aviation.owning
Default OK, Thinking-Cap Time...
Jay - If you get desperate, you might be able to create this problem on
the ground using a hand held or jury rigged electric motor to spin the
alternator rather than having to run the engine. This would allow
better diagnostic capability using an oscilloscope.
However, if the problem only occurs only at higher amperage loads, a
fractional hp electric motor won't be able to spin the alternator.
Likewise the RPM may be a problem. Alternators spin pretty fast at
cruise - like over 10,000 rpm.
Old November 18th 05, 05:13 AM posted to rec.aviation.owning
If you try this, keep a fan blowing on the alternator. Even in cold
temperatures, it will need cooling air.
George Patterson
If a tank is out of ammunition, what you have is a sixty ton portable
radio.
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
FS9 Time Zone Files in BETA Test DDT Simulators 3 April 5th 04 06:06 PM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 06:44 AM
