"It triggers the warning when the spoilers are unlocked and the
airspeed exceeds 25 knots." The same conditions are satisfied for landing approach with the gear down. I expect the answer is that the 302, containing a full airdata and GPS system, can easily determine that a takeoff has started. Indeed, it does that to start the logger function. I use the airbrake warning of the 302 as well. It usually bitches at me for just one cycle on takeoff as I always use the airbrakes until I have good aileron control. Andy |
Andy wrote:
"It triggers the warning when the spoilers are unlocked and the airspeed exceeds 25 knots." The same conditions are satisfied for landing approach with the gear down. I expect the answer is that the 302, containing a full airdata and GPS system, can easily determine that a takeoff has started. Indeed, it does that to start the logger function. I wrote that poorly. This is what the manual says: "When airspeed rises above 25 knots, the alarm sounds". Just having the airspeed above 25 knots won't do it, as you note, it is the "rising above". -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Jet engines vs. leaf blowers | 01-- Zero One | Soaring | 6 | September 8th 05 01:59 AM |
Gear Warning Switches on a Mosquito | scooter | Soaring | 6 | March 9th 05 01:15 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
gear warning plus | K.P. Termaat | Soaring | 0 | September 8th 03 08:33 AM |
