![]() Ron Rosenfeld wrote: On Sat, 07 Feb 2004 05:31:48 -0800, wrote: There are some approaches where the straight-in minimums step-up for each higher approach category because of a turning missed approach obstacle issue that affects the higher turning radii more than the lower. Are you certain that is the reason for the higher minima? Could you give an example of an approach where you believe that to be the case? Medford, Oregon, ILS Runway 14. Note the turning missed approach and a higher DA/H for each higher approach category. I am questioning it because I have also seen straight-in minimum visibility step-up for higher approach category a/c where the missed approach is NOT a turning one. So clearly, at those approaches, turn radius is not an issue. An example of this would be the LOC29 approach at KPWM. Visibility minimums are based on Approach Category and the geometric relationship of the height of the MDA or DA/H. It is not directly related to any turning missed approach issue. Also, well -- I don't know if you use Jepp charts or NOS charts. But on my Jepp charts, the minima for straight in approaches is subdivided by aircraft category. The minima for circle-to-land approaches is subdivided by speed in knots. To me this suggests that the maneuvering speed is important only in the circle-to-land approach, and not in the straight-in approach. The information in the AIM, and in the FAA Instrument Flying Handbook, and an FAA inspector with whom I used to fly from time to time, all have indicated to me that the increased category minima for increased a/c maneuvering speeds only apply to circling approaches, at least for TERPS'd approaches. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
