Groen Bros. DARPA Award
Old November 19th 05, 08:18 AM posted to rec.aviation.rotorcraft
Default Gyro's was Groen Bros. DARPA Award
"boB" wrote in message
Shiver wrote:
He is a big big champion of the vertical (centerline) stabilizer on
gyros and I do believe has had his share of arguements with the
developers of the RAF gyros on this subject. He has talked about the
dangers of buntover with resulting death in this group at various
times.
Buntover??? In my reading I haven't run across that term. I know how to
keep from causing the normal spike knock, tail boom strikes, 0 G pitch
down and mast bumping problems. From the word, is it a forward pitchover
caused by the horizontal stabilizer being too low?
boB,
SAG 70
Buntover is just another term for a power push over (PPO). From what I've
gathered in my reading through the years, it's not as much an issue with the
horizontal stabilizer as it is with the placement of the engines thrust line
relative to the vertical CG of the aircraft. Gyros like the stock RAF2000
have the thrust line at a significant distance above the vertical CG of the
aircraft. That imparts a nose down moment when under power. The main
rotor, because it's tilted aft in flight, offers a counter force to the
forward pitching moment. If you unload the main rotor enough, there's not
counter force to that forward pitching moment caused by the engine thrust
line being above the CG and over she goes.
A properly placed and sized horizontal stab can go a long way toward
reducing the possibility of this problem but it doesn't address the root
cause. That being a thrust line that's not properly in line with the
vertical CG of the aircraft. At least that's my understanding. If I'm too
far off on this, I'm sure someone will correct me! :-)
Fly Safe,
Steve R.
Old November 19th 05, 09:27 AM posted to rec.aviation.rotorcraft
times.
boB,
SAG 70
Fly Safe,
Steve R.
Thanks Steve. That sounds like two forces working against each other.
That doesn't seem to be efficient as far as strain on the systems.
Something similar on my Sprint II with the engine and prop above the
vertical CG. If the engine quits or even when throttling down the nose
pops up which screwed up my landings early on. I had been fixed on the
RAF2000 but hadn't really looked at the competition before. I
appreciate all the advice.
boB,
SAG 70
U.S. Army Aviation (retired)
Central Texas - 5NM West of Gray Army Airfield (KGRK)
Old November 19th 05, 06:50 PM posted to rec.aviation.rotorcraft
Thanks Steve. That sounds like two forces working against each other. That
doesn't seem to be efficient as far as strain on the systems. Something
similar on my Sprint II with the engine and prop above the vertical CG. If
the engine quits or even when throttling down the nose pops up which
screwed up my landings early on. I had been fixed on the RAF2000 but
hadn't really looked at the competition before. I appreciate all the
advice.
boB,
SAG 70
Your welcome Bob! You're right, these forces are working against each
other, and not in a good way. Designs like this have been flown for years
and there are still people out there that insist that it's perfectly safe.
They may have learned to deal with it but the unfortunate fact is that too
many people have died because of the high thrust line designs that didn't
have to.
Personally, I wouldn't touch an RAF2000 with a 10 foot pole but the Groen
Bros version of it looks like a very nice alternative if you've really got
your heart set on a fully enclosed cabin. Of the more open designs around,
I'm really impressed with the Air Command. They are one of the few kit
manufacturers that had the guts and integrity to completely redesign their
gyros when it finally became clear what the high thrust line issues were
doing to the aircrafts stability. They don't sell anything now that's not
centerline thrust and they offer a very reasonable upgrade kit for those who
still have the older high thrust line gyros sitting in the barn. They also
issued, if I'm not mistaken, and air worthiness directive to all owners of
the old high thrust line machines, advising them to "not" fly until it's
been converted to centerline thrust!
Are you familiar with the PRA (Popular Rotorcraft Association)? They can be
found at www.pra.org and are a great source of info on experimental gyros
and helicopters. Also, check out this forum if you're not already familiar
with it,
http://www.rotaryforum.com/index.php
Lots of really great people and good information. Just be aware that the
gyro folks can be, shall we say, "passionate," about their machines so it
sometimes helps to have a thick skin around there. ;-)
Best of luck,
Steve R.
Old November 20th 05, 03:00 AM posted to rec.aviation.rotorcraft
Best of luck,
Steve R.
Thanks Steve. I really hope someday to fly again. Until then I have a
lot of time to research. I'm very glad I found you all.
boB,
SAG 70
U.S. Air Force award of four rocket launches this year is likely to be delayed Larry Dighera Military Aviation 15 May 14th 04 01:58 PM
Groen Bros. Al Colunio Rotorcraft 6 May 8th 04 02:22 AM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 03:01 PM
Air Force announces small diameter bomb contract award Otis Willie Military Aviation 0 October 9th 03 09:52 PM
Army officer recieves Tuskegee Airman Award Otis Willie Military Aviation 0 August 21st 03 09:15 PM
