OK, Thinking-Cap Time...
Old November 19th 05, 04:00 PM posted to rec.aviation.owning
Default OK, Thinking-Cap Time...
"George Patterson" wrote in message
news:Q%7ff.60$N44.3@trndny08...
snip
Alternator problem. Possibly a filter, but my guess is a diode is going
bad.
snip
Diodes are solid state devices which either work, are open (most common
failure), or are shorted out (less common failure). They don't suffer from
"going bad" or "getting weak". They either work or they don't. If they are
intermittant, it's a connection, not the diode itself.
DB
(Many years of Electronics experience)
Old November 20th 05, 12:02 AM posted to rec.aviation.owning
"Doodybutch" writes:
Well, maybe... I have had some larger power diodes whose *internal*
bonds would open when the diode got hot. When it cooled again, guess
what.
I also had a matrix of small-signal glass diodes that tested just
fine with an ohmmeter, but in operation.... turns out some would
"zener" when tested with the 12v that was used in the circuit.
But I really doubt that Jay's issue is alternator diodes....
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Logging time on a PCATD [email protected] Instrument Flight Rules 3 December 18th 04 05:25 PM
FAA Application -- kinds of time Gary Drescher Instrument Flight Rules 5 November 23rd 04 02:33 PM
FS9 Time Zone Files in BETA Test DDT Simulators 3 April 5th 04 06:06 PM
Retroactive correction of logbook errors Marty Ross Piloting 10 July 31st 03 06:44 AM
