"Doodybutch" writes:
Diodes are solid state devices which either work, are open (most common failure), or are shorted out (less common failure). They don't suffer from "going bad" or "getting weak". They either work or they don't. If they are intermittant, it's a connection, not the diode itself. Well, maybe... I have had some larger power diodes whose *internal* bonds would open when the diode got hot. When it cooled again, guess what. I also had a matrix of small-signal glass diodes that tested just fine with an ohmmeter, but in operation.... turns out some would "zener" when tested with the 12v that was used in the circuit. But I really doubt that Jay's issue is alternator diodes.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 05:25 PM |
FAA Application -- kinds of time | Gary Drescher | Instrument Flight Rules | 5 | November 23rd 04 02:33 PM |
FS9 Time Zone Files in BETA Test | DDT | Simulators | 3 | April 5th 04 06:06 PM |
Retroactive correction of logbook errors | Marty Ross | Piloting | 10 | July 31st 03 06:44 AM |
