According to a program on the Discovery channel they were putting guys
into Spitfires that would be the equivelant of a low time solo student now days. I wouldn't be surprised if that's true, but I've heard a lot of "facts" on the Discovery Channel (and the History Channel) that were NOT true. I doubt their writers are well-trained in historical research and evaluation of sources. There's a lot of nonsense in books, too, which those writers probably draw on as 'gospel." Did you know, for example, that the top speed of the Vultee BT-13 was 190 miles per hour? The F4U also is *big*, heavy, and although a carrier bird is not exactly a short field plane. There was a recent discussion of that in another newsgroup and I was surprised at how quickly an F4U can get off. I don't remember the number, but I think it was around 2,000 feet. I don't remember if they hald a larger engine than the "Jug", but I think they did. Both the P-47 ands the F4U had the PW R-2800 engine. I vaguely recal that the Goodyear FG-1, based on the F4U, may have had a larger engine. The Jug ran a miserly 80 to 90 gallons per hour at economy cruise as I recall. That sounds about right. I'd like to have one of the tricycle gear Skyraiders. I think most of those were tail draggers. I've never even HEARD of an AD that was not a tail dragger. Do you know if there's a picture of a tricycle gear AD on the net? That thing is huge and had the largest radial engine we ever used, as far as I know. I think it was a 3350. I think there was a 43XX radial that was used on the Connie or the DC7, but my memory is quite vague on that. vince norris |
vincient i think he has the skyraider confused with the T-28, both look
similer, one trike one taildragger, both navy. |
On Sat, 19 Nov 2005 21:46:14 -0500, vincent p. norris
wrote: snip The Jug ran a miserly 80 to 90 gallons per hour at economy cruise as I recall. That sounds about right. I'd like to have one of the tricycle gear Skyraiders. I think most of those were tail draggers. I've never even HEARD of an AD that was not a tail dragger. Do you know if there's a picture of a tricycle gear AD on the net? I've been searching, but not found any yet. It may just a faulty memory, but I'm sure I saw one some place. That thing is huge and had the largest radial engine we ever used, as far as I know. I think it was a 3350. Same engine as on the B-29. Early versions were 2500 HP and later versions were 2800 HP. How'd you like to feed that for a trip from coast to coast? All that fuel with about the same cruse when light (maybe 15,000#?) as a Bonanza.. I believe the 3350 was the largest every used on a single engine airframe, but here were larger on multi engine planes. I think there was a 43XX radial that was used on the Connie or the DC7, but my memory is quite vague on that. vince norris Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
The Goodyear FG Corsairs ran the 4360 as did the Martin Mauler and the
Republic XP-72 until the contract was cancelled just after acceptance testing. The 4360 was also in the Boeing 377, B-36, B-50 and some others. There was also the Lycoming 7755 which was 36 cylinders with variable valve timing. Initial tests indicated 5000 hp with projected top hp of 7000 but... then came the turbines. I think the Smithsonian has the only remaining example. "Roger" wrote in message ... On Sat, 19 Nov 2005 21:46:14 -0500, vincent p. norris wrote: snip The Jug ran a miserly 80 to 90 gallons per hour at economy cruise as I recall. That sounds about right. I'd like to have one of the tricycle gear Skyraiders. I think most of those were tail draggers. I've never even HEARD of an AD that was not a tail dragger. Do you know if there's a picture of a tricycle gear AD on the net? I've been searching, but not found any yet. It may just a faulty memory, but I'm sure I saw one some place. That thing is huge and had the largest radial engine we ever used, as far as I know. I think it was a 3350. Same engine as on the B-29. Early versions were 2500 HP and later versions were 2800 HP. How'd you like to feed that for a trip from coast to coast? All that fuel with about the same cruse when light (maybe 15,000#?) as a Bonanza.. I believe the 3350 was the largest every used on a single engine airframe, but here were larger on multi engine planes. I think there was a 43XX radial that was used on the Connie or the DC7, but my memory is quite vague on that. vince norris Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Australia F111 to be scrapped!! | John Cook | Military Aviation | 35 | November 10th 03 11:46 PM |
