Gear Warning
Old November 20th 05, 08:30 PM posted to rec.aviation.soaring
Default Gear Warning
At 07:18 20 November 2005, Ramy Yanetz wrote:
I agree traffic and landing area may not need checklist,
but definitely
checking radio frequency and volume, trim for pattern
speed and checking the
spoilers must be part of every landing checklist.
Ramy
Personally, they are not part of my pre-landing checks.
If I've been flying in icing conditions (wave) I'll
try the airbrakes on the way down, apart from that
it is not necessary to check them prior to landing.
I don't adopt the approach speed until just prior
to base leg and I always trim after changing speed
whenever I'm flying, so why have it as part of a checklist?
The radio check may be valid in the States but isn't
necessary in the UK.
Old November 20th 05, 09:32 PM posted to rec.aviation.soaring
but definitely
Ramy
To ensure they do operate (freezing shut is not the only way for them to
fail) and to activate the gear warning device.
Is that because the field frequency is the same as the one you use
during the flight, or because the glider fields you use don't use a
radio in the pattern? I'm assuming you'd use the radio at a regular
airport with mixed traffic.
Eric Greenwell
Washington State
USA
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
Gear Warning Switches on a Mosquito scooter Soaring 6 March 9th 05 01:15 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
