It may be the localizer that you are interfering with, not only the GS.
Roy Smith wrote: Mark Hansen wrote: Well, if it's only a problem when an aircraft is on the ILS and it's below 800/2, and given that ATC isn't going to release an IFR departure if an aircraft is on the ILS, then it doesn't appear to be a problem. I'm not sure that's the only time it's a problem. It just the minimum that the tower is required to keep the area clear. I would expect that ILS can be interfered with regardless of the current weather. I think the idea is that even a distorted GS will be accurate enough to get you to within 800/2 of the runway. |
Isn't the localizer antenna down at the other end of the runway? If a pilot
is departing from the end, the localizer signal should be 700 feet wide at that point. Bob Gardner Bob Gardner "Newps" wrote in message . .. It may be the localizer that you are interfering with, not only the GS. Roy Smith wrote: Mark Hansen wrote: Well, if it's only a problem when an aircraft is on the ILS and it's below 800/2, and given that ATC isn't going to release an IFR departure if an aircraft is on the ILS, then it doesn't appear to be a problem. I'm not sure that's the only time it's a problem. It just the minimum that the tower is required to keep the area clear. I would expect that ILS can be interfered with regardless of the current weather. I think the idea is that even a distorted GS will be accurate enough to get you to within 800/2 of the runway. |
![]() "Bob Gardner" wrote in message news ![]() Isn't the localizer antenna down at the other end of the runway? If a pilot is departing from the end, the localizer signal should be 700 feet wide at that point. They're at opposite ends of the runway and you're not going to interfere with both of them simultaneously, but your taxi route may take you through both of them. How many fields are there where this is a concern? I would expect most fields with the congestion to require marked ILS critical areas to have full-time towers. |
Steven P. McNicoll wrote:
"Bob Gardner" wrote in message news ![]() How many fields are there where this is a concern? I would expect most fields with the congestion to require marked ILS critical areas to have full-time towers. I can't provide a cite, but I was told recently that there are ILS critical areas at part-time towered airports. |
I can't provide a cite, but I was told recently that there are ILS critical areas at part-time towered airports. Schenectady County Airport, KSCH, is a part time towered airport with an ILS critical area. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Roy Smith" wrote in message ... Interestingly enough, at both ends of the runway at HPN, the ILS Hold Short lines are only on the taxiways on the left side (as viewed from the approach) of the runway, which is the side the GS antenna is on in both cases. If there was no access to the side on which the GS is sited there'd be no need to protect the GS critical area. |
Up until 2 months ago, there was an ILS critical area at an untowered
field.. KGLS Galveston, TX, and it had been there since i started flying in 2000. Galveston now has a part time tower. Dave wrote: Steven P. McNicoll wrote: "Bob Gardner" wrote in message news ![]() How many fields are there where this is a concern? I would expect most fields with the congestion to require marked ILS critical areas to have full-time towers. I can't provide a cite, but I was told recently that there are ILS critical areas at part-time towered airports. |
![]() Bob Gardner wrote: Isn't the localizer antenna down at the other end of the runway? If a pilot is departing from the end, the localizer signal should be 700 feet wide at that point. I've had discussions with the FAA's flight check pilots as they are out flying approaches checking our navaids. The critical area can be for both the GS and Loc. Their equipment is so good in the flight check aircraft they can tell if a person walks across the middle of the runway from a 10 mile final. |
comment period reopened on DC area "ADIZ" | Bob Noel | Piloting | 3 | November 15th 05 04:39 PM |
Los Angeles radio tower crash kills 2 | Paul Hirose | Piloting | 178 | August 6th 05 03:46 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
ILS Critical Area signage: Localizer or Glideslope? | Adam K. | Instrument Flight Rules | 4 | October 30th 03 10:09 PM |
Patrick AFB Area Log, Monday 30 June 2003 | AllanStern | Military Aviation | 0 | July 1st 03 06:37 AM |
