ILS critical area when the tower is closed?
Old November 21st 05, 03:01 AM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
wrote in message news:CX9gf.1261$pF.1153@fed1read04...
It's a problem during a coupled approach especially if the pilot is
planning to do an autoland.
It's not a problem if the weather is good.
Old November 21st 05, 03:02 PM posted to rec.aviation.ifr
Not so, Steve. It can cause control problems and certainly adversely
affect an autoland. That is why your handbook contains a caveat about
such approaches.
Approach couplers and autoland systems are weather independent.~
Old November 21st 05, 03:48 PM posted to rec.aviation.ifr
Limitations on the approach chart probably do not allow the
ILS when the tower is closed or more than one hour after the
last weather observation.
news:cjlgf.4216$pF.687@fed1read04...
| wrote in message
the pilot is
certainly adversely
caveat about
| such approaches.
independent.~
Old November 21st 05, 04:27 PM posted to rec.aviation.ifr
"Jim Macklin" wrote in message
news:g0mgf.4463$QW2.2168@dukeread08...
What airport are you referring to?
Old November 21st 05, 11:21 PM posted to rec.aviation.ifr
On Mon, 21 Nov 2005 09:48:30 -0600, "Jim Macklin"
RW 29 at PWM has an ILS hold charted on the airport diagram, but I
don't see anything preventing it's use when the tower is closed on the
approach chart:
http://204.108.4.16/d-tpp/0511/00329IL29.PDF
Old November 21st 05, 04:10 PM posted to rec.aviation.ifr
wrote in message news:cjlgf.4216$pF.687@fed1read04...
such approaches.
You're mistaken. There's no need for approach couplers and autoland systems
when the weather is good. It's not a problem because the pilots can see.
Old November 21st 05, 05:14 PM posted to rec.aviation.ifr
wrong. There might be "need" to do autolanding for 3 month (?)
currency. I hear this often at night for jets going into SFO.
Granted the pilots turn off the autopilot with no loss of
safety but the need is still there.
Gerald
Old November 21st 05, 05:20 PM posted to rec.aviation.ifr
"Gerald Sylvester" wrote in message
news
currency.
It's not a problem because the pilots can see. The need for currency
doesn't alter the weather.
SFO has a full-time tower.
Old November 22nd 05, 03:33 AM posted to rec.aviation.ifr
currency.
correct but there is a need to do an autoland. It is not
*required* since the weather is good enough but the
correct but I was referring to jets asking to do a
CAT III approach for currency even though it is VFR.
Gerald
Old November 22nd 05, 05:22 AM posted to rec.aviation.ifr
. net...
Don't be silly. There's clearly no need to do an autoland in good weather.
We're talking about ILS critical areas when the tower is closed.
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
