Last Plane Without a Computer
Old November 21st 05, 04:14 AM posted to rec.aviation.military,rec.aviation.owning
Default Last Plane Without a Computer
I'm going to guess the last successful airliner without a computer was
the Boeing 737 original version. And the largest sucessful airliner
without a computer was the Boeing 747 original. And I believe the last
successful large bomber without a computer was the B-47. Can anyone
confirm or refute this?
In particular, no internet source says if the engine controllers were
mechanical or computer.
Definitions:
There can be no necessary computer at all. Not in the engine
controller nor in the flight controls. If there is a computer, the
plane should be useable with that computer turned off.
A computer is an electronic machine with a CPU, RAM, and software.
Mechanical computing devices do not count for this exorcise (though
they are interesting).
-Curious
-Kitplane01
Old November 21st 05, 04:27 AM posted to rec.aviation.military,rec.aviation.owning
The B-47 had a bombing and navigation system that included an analog
computer.
Old November 21st 05, 07:02 AM posted to rec.aviation.military,rec.aviation.owning
"Brett" writes:
computer.
Yeah, but he defined computer, and his definition clearly limits it to
digital computers.
David Dyer-Bennet, , http://www.dd-b.net/dd-b/
RKBA: http://noguns-nomoney.com/ http://www.dd-b.net/carry/
Pics: http://dd-b.lighthunters.net/ http://www.dd-b.net/dd-b/SnapshotAlbum/
Dragaera/Steven Brust: http://dragaera.info/
Old November 21st 05, 10:01 AM posted to rec.aviation.military,rec.aviation.owning
"David Dyer-Bennet" wrote:
"Brett" writes:
last
computer.
digital computers.
Well "his definition" should have come before his claim of what didn't have
them.
Old November 21st 05, 05:06 PM posted to rec.aviation.military,rec.aviation.owning
Didn't the original 737 have a fuel computer (really just a calculator,
but still electronic with CPU, etc)? I'm not sure what you mean by
"software" the line between "software" and "firmware" is pretty blurry
to me, but then again, I've worked as an engineeer designing both. You
can update the "software" of the caluclator by changing out the chip.
-Robert
Old November 21st 05, 08:47 PM posted to rec.aviation.military,rec.aviation.owning
"Brett" writes:
"Brett" writes:
last
computer.
digital computers.
them.
Or you should have read to the end of his message before responding.
Old November 21st 05, 09:07 PM posted to rec.aviation.military,rec.aviation.owning
"Brett" writes:
"Brett" writes:
was
airliner
last
anyone
computer.
digital computers.
have
them.
Nah, if he wants to use his own definition of a computer his post should
have started with it.
So when his opening paragraph was garbage, the rest of it got dumped.
Old November 22nd 05, 12:18 AM posted to rec.aviation.owning
I have no idea if this is true or not, but the B-747 was certificated after
the B-737 so if neither had a computer then the 737 couldn't be last.
Also, are you considering only airplanes from the US? I suspect that some
Russian airliners and/or bombers from later dates didn't have computers.
-Elliott Drucker
Old November 22nd 05, 08:29 AM posted to rec.aviation.military,rec.aviation.owning
"james cho" wrote in message
That definition of "electronic computer" is limited to modern digital
microcomputers. Why not include analog computers?
james
Why not include mechanical computers?
Old November 23rd 05, 12:17 AM posted to rec.aviation.owning
I flew a B-707 that had two INS's and a Loran. All three were
certainly computers of the digital kind. Before that a 1969 G-II with
the same INS.
Rental policy Robert Piloting 83 May 13th 04 05:29 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
