The seatback packs arent hard to use, but your back passengers may not like
them cutting into their legroom. I dont know about all the systems, but my Aerox has it's flow needle about halfway up the line so you can see it pretty easy. But to actually turn up or down the amount going to an individual line you have to be able to reach the 4place regulator. And to see how much you have remaining in the tank you have to see the tank. The alternative, unless you rent, is to retrofit it into your airplane. Aerox makes kits to do this, I'm sure the other companies do too. The tank is in the tailcone more than likely, and a block is put in the ceiling with 4 ports and gauge. Pretty slick, but not cheap. $1,500 for the hardware, and a few hours of labor. This is for a fairly large tank, not the size of the portables. Fill it from the tank, or a port in the tail. Chris "dutch" wrote in message link.net... I have a new IFR rating and am considering some higher altitude flights now that I can drop down through cloud decks. Question: for those of you who carry oxygen, how do you secure the tank so that you can still reach and see to adjust the flow valve? Vendors sell seatback packs, but those sound difficult to use. |
| Thread Tools | |
| Display Modes | |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| FS: Soft Comm ATC-4Y 4 place portable intercom | Jaysen Underhill | Instrument Flight Rules | 0 | December 11th 03 10:41 PM |
| oxygen sensors for aircraft | Air Methods Corporation | Home Built | 0 | September 21st 03 08:16 PM |
| FS: Soft Comm ATC-4Y 4 place portable intercom, $75.00 | Jaysen Underhill | Instrument Flight Rules | 0 | September 4th 03 05:41 AM |
