Nike jet gear not opening..
Old November 21st 05, 08:12 PM posted to rec.aviation.piloting
Default Nike jet gear not opening..
"gatt" wrote in message
"Jacob" wrote in message news:TTogf.22089
A gulfstream jet carrying Nike executives has a landing gear problem and
is trying to burn fuel to land at Hillsboro, Oregon airport. On CNN.
Been listening to PDX ATC and some other freqs. Of course the FireDept is
preparing, airplanes south of Hillsboro are being vectored around. PDX
Approach and Departure has been warning aircraft of two media helicopers
hovering north of the airport at 1,000 ft, and Marine Drive is/was closed.
Awhile ago he reported fuel down to 12,000lbs from 26,000.
-c
Gears down now, hooray for GA! Now the network newsmongers have nothing but
a good ending to report.
DW
Old November 21st 05, 10:42 PM posted to rec.aviation.piloting
"Darkwing" theducksmail"AT"yahoo.com wrote in message
is preparing, airplanes south of Hillsboro are being vectored around.
PDX Approach and Departure has been warning aircraft of two media
helicopers hovering north of the airport at 1,000 ft, and Marine Drive
is/was closed. Awhile ago he reported fuel down to 12,000lbs from 26,000.
It's a good thing they don't have UHF scanners to listen to military bases.
This stuff happens all the time there but just doesn't get the press cause
they're not broadcasting the comss on VHF.
Old November 22nd 05, 06:54 PM posted to rec.aviation.piloting
"John Doe" wrote in message news:Y8sgf.14545
bases. This stuff happens all the time there but just doesn't get the
press cause they're not broadcasting the comss on VHF.
A big clue is when the fire department shuts down the roads along the
airport runway and starts staging their equipment for rapid deployment.
Although, the ATC chatter was truly fascinating. I heard the tower reporting
that the problem hadn't been fixed, at one point the pilot said "it didn't
work, we need to try something different", heard him cleared for another
flyby and, later, 'We're bringing the engine back up.' (Self: "Engine?!")
Followed by "Looks good. You're clear for the visual approach at your
discretion."
-c
Jet engines vs. leaf blowers 01-- Zero One Soaring 6 September 8th 05 01:59 AM
A&P heroics Jim Piloting 31 July 18th 05 07:26 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
