Stormscope
Old November 21st 05, 04:07 PM posted to rec.aviation.ifr
Default Stormscope
Stubby wrote:
The explanation I got seems better: The atmosphere attenuates some
radio frequencies more than other (I believe high frequencies are
attenuated more than low, but it may be way more complex.) A lighting
flash is an impulse and thus, has all frequencies present at the same
level. The distance sensor can measure the level of 2 frequencies and
derive the distance. In practice I've heard that 6 frequencies are used
but that implies 36 amplitude ratios are being used.
Ding ding ding ding ding ding! Finally someone responded with the correct answer.
Dave
Old December 4th 05, 07:21 PM posted to rec.aviation.ifr
Default Stormscope
Dong, dong, dong, dong, dong...
Perhaps the current Stormscope uses this method; Ryan's original work used a
spot frequency (50 kHz) and amplitude discrimination. And Ryan didn't
"invent" it. The seminal work was done by Smythe Research Associates in San
Diego on a field trip to the South Pacific.
Strikefinder was the first to use multiple frequencies across a rather broad
bandwidth.
"Dave Butler" wrote in message
news:1132589727.740244@sj-nntpcache-3...
answer.
Dave
Old December 4th 05, 07:42 PM posted to rec.aviation.ifr
Default Stormscope
Just for clarity, using multiple frequencies is not the key to its
working. A pair (2) will suffice. Using multiple frequency (ratios)
will probably increase the accuracy, however.
Hats off to whoever invented it. Very clever.
bandwidth.
answer.
Dave
Old December 4th 05, 07:51 PM posted to rec.aviation.ifr
Default Stormscope
God invented it. I don't remember who first discovered it, but
dispersion as a phenomena has been known for quite some time.
Matt
Pinout for StormScope WX-900 epotenziani Products 0 August 22nd 05 08:32 PM
Shops for Stormscope Install - Madison WI Jim Burns Owning 3 February 6th 05 06:48 PM
ADF vs. StormScope antenna David Megginson Instrument Flight Rules 0 September 6th 03 10:03 PM
WX1000 Stormscope battery D. J. Gooding Owning 2 August 9th 03 02:25 AM
FS: WX-1000E Stormscope Lenny Sawyer Owning 0 July 1st 03 02:29 AM
