![]() Chris Quaintance wrote: Hi Folks- Without descending into the madness of the other thread, I have a couple of questions regarding the use of a VFR GPS while IFR. Hypothetically, let's say I was flying IFR from Santa Monica, CA to San Jose, CA (SMO to RHV). The weather is CAVU. The wx is irrelavant. I am filed /A and cleared via a fairly standard route on victor airways. Just past the mountains and still 150 miles from RHV, Oakland Center asks me if I am "GPS equipped." I answer in the affirmative as I have my trusty Garmin 296 mounted on the yoke. I am then cleared direct GILRO, direct RHV and I accept the clearance. I proceed to fly said clearance and land at my destination without futher issue. I realize this is common practice. It seems to me it would not be strictly "legal" as I would be relying on the 296 for primary navigation. That's because it isn't legal. To be legal you have to be on a vector, direct when able. My questions: --Where did this situation actually break down in terms of regulations? When you accepted a direct clearance that you can't fly without the GPS. --In CAVU weather, the risk of this becoming a problem is basically nil. However, in IMC, I would consider it to be potentially problematic (i.e. the 296 goes Tango Uniform and I'm not exactly sure of my position using my trusty VOR's). Right, good weather only makes you feel better, doesn't affect the legality. Would you consider this risk neglible? Yes. |
![]() "Newps" wrote in message . .. That's because it isn't legal. What law is being violated? To be legal you have to be on a vector, direct when able. In what law is that requirement found? |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
