ILS critical area when the tower is closed?
Old November 21st 05, 08:16 PM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
"Newps" wrote in message
The airlines will always fly the ILS if there is one up and running. They
are required to.
Do you suppose you could cite that requirement? I've known many an airline
flight to do a visual approach when there was a perfectly good ILS approach
available.
Old November 21st 05, 08:19 PM posted to rec.aviation.ifr
They are required to.
Is this a FAR requirement or airline's operational procedural requirement?
Peter
Old November 21st 05, 08:26 PM posted to rec.aviation.ifr
"Peter R." wrote in message
Neither.
Old November 22nd 05, 03:24 AM posted to rec.aviation.ifr
Neither.
91.129 requires that the ILS be followed at a Class D airport. It does
not require that the full procedure be flown. If cleared for a visual
to an ILS runway, for example, the 121 crew must have the ILS tuned and
identified and use it once lined up with the runway.
Further, this 91.129 requirement is included in every carrier's flight
operations policy manual (a POI-approved document) to be applied for any
runway end with an operating ILS, Class D or not.
Old November 22nd 05, 05:39 AM posted to rec.aviation.ifr
wrote in message news:rbwgf.4658$pF.1342@fed1read04...
not require that the full procedure be flown. If cleared for a visual to
The requirement in FAR 91.129 is that a large or turbine-powered airplane
approaching to land on a runway served by an ILS must fly at an altitude at
or above the glide slope. The claim by Newps was; "The airlines will always
fly the ILS if there is one up and running. They are required to."
Old November 22nd 05, 09:55 AM posted to rec.aviation.ifr
I didn't infer that he meant the full procedure. But, perhaps he did.
Newps?
Old November 21st 05, 08:33 PM posted to rec.aviation.ifr
Both. The FAA makes sure the airline puts it into their ops specs. If
there is an operating ILS to the runway that they are landing on they
have to use it. If a controller clears pretty much any jet with no
restrictions on the size of the pattern almost without fail they will
turn final at the outer marker.
Old November 21st 05, 08:35 PM posted to rec.aviation.ifr
there is an operating ILS to the runway that they are landing on they have
restrictions on the size of the pattern almost without fail they will turn
Please cite the applicable FAR.
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
