C-172 Fuel
Old November 22nd 05, 02:37 PM posted to rec.aviation.piloting
Default C-172 Fuel
On Mon, 21 Nov 2005 18:11:10 -0500, Ron Natalie
The reason you are told to run in a single tank mode abouve
5000' is to get increased fuel flow through whatever line you
are using to avoid vapor lock. It's a relative new (to the
design) suggestion.
This appears to be model-specific. There is no such recommendation,
placard, or instruction in the aircraft or POH for the R and S models
that I have flown/have access to, and except to actively balance the
tanks I don't operate with the selector out of the 'both' position,
regardless of altitude.
They've made some changes in the system with the newest models, the
newer (R,S) models have vented caps on both tanks, as well as the
normal one on the left strut (in addition to some minor things for the
injected engine).
Old November 22nd 05, 05:22 PM posted to rec.aviation.piloting
Default C-172 Fuel
G Farris wrote:
I have heard that the left tank becomes slightly pressurized, due to the
forward-facing vent on that tank, which is why it drains faster than the
other. I do not claim this to be a fact - just something I've heard.
The left tank becomes pressurized because the vent tube is slightly out
of rig. It's supposed to be directly behind the strut. If it gets a
clear view of the incoming slipstream it forces a lot more air into the
tank. That forces fuel from the left to the right tank via the vent
line above the headliner in the cockpit. You will never solve the
problem until the vent tube under the left wing is positioned correctly
and then you only mitigate the problem to a certain degree.
Old November 22nd 05, 06:14 PM posted to rec.aviation.piloting
Default C-172 Fuel
It IS model specific. WIthout loading up the CDROM with the type
certificates, it was the C model through the H model that had this required
placard on the fuel handle ... as my feeble brain recalls.
Old November 22nd 05, 07:54 PM posted to rec.aviation.piloting
Default C-172 Fuel
Seems to be a popular misconception as to how that fuel gets
across to the other side. It can flow through the FUEL lines, at any
fuel level, while the selector is on both. If, for instance, the
airplane is parked left wing low, the fuel will run down through the
fuel line from the right tank, through the selector valve, and up the
other fuel line into the left tank. No mystery at all. If the tanks
have enough fuel, it will run out the vent onto the ramp. Stopping it
requires placing the selector on L or R or OFF. The old Cessna 150s,
with their on/off system, had the lines teed together before the valve
and would do this anytime, valve on or off.
The fuel will run across the VENT line only if the tanks are
full.
The fuel venting system applies the same pressure to both tanks.
The vent, whether behind the strut or below it, leads to the left tank,
and the vent line from that tank across the right tank makes sure that
the pressures are equal. Unequal pressures are a result of leaking fuel
caps, either at the gasket or through a defective vent check valve, and
air will flow through the cap into the tank and cause airflow one way
or the other through the vent line, upsetting the pressure balance and
causing one tank to drain faster than the other. Pressures are usually
negative if the check valve leaks, and possibly could go positive if
the gasket had a forward-facing leak. I've seen split gaskets on fuel
caps.
The vent is located aft of the strut to minimize icing blockage,
and one or both caps has a silicone check valve to let air into the
tanks in case of vent icing. That valve deteriorates over time and lets
air out of the tank. The valve disc isn't available as a separate part;
the cap must be replaced. Thankfully, they aren't expensive like
Piper's.
Dan
Old November 22nd 05, 08:24 PM posted to rec.aviation.piloting
Default C-172 Fuel
I should have quoted a couple of sources regarding fuel tank venting.
For the US, here's the FAR, in part, that deals with it. Note that
(a)(1) deals with the icing problem of vents, hence Cessna's locating
it behind the strut, and (a)(4) deals with interconnected tanks such as
the 172/182's, so a vent system common to both tanks is required to
keep tank pressures equal.
23.975 Fuel tank vents and carburetor vapor vents.
(a) Each fuel tank must be vented from the top part of the expansion
space. In addition -
(1) Each vent outlet must be located and constructed in a manner
that minimizes the possibility of its being obstructed by ice or other
foreign matter;
(2) Each vent must be constructed to prevent siphoning of fuel
during normal operation;
(3) The venting capacity must allow the rapid relief of excessive
differences of pressure between the interior and exterior of the tank;
(4) Airspaces of tanks with interconnected outlets must be
interconnected;
(5) There may be no point in any vent line where moisture can
accumulate with the airplane in either the ground or level flight
attitudes, unless drainage is provided. Any drain valve installed must
be accessible for drainage;
(6) No vent may terminate at a point where the discharge of fuel
from the vent outlet will constitute a fire hazard or from which fumes
may enter personnel compartments; and
(7) Vents must be arranged to prevent the loss of fuel, except
fuel discharged because of thermal expansion, when the airplane is
parked in any direction on a ramp having a one percent slope.
snip
Canadians can find exactly the same thing in CAR 523.975.
Dan
Old November 23rd 05, 12:06 AM posted to rec.aviation.piloting
Default C-172 Fuel
Seth Masia schrieb:
I trained in and flew 172s for years out of an airport with a field
elevation of 5900 feet. No one on the field ever heard of this placard; no
one ever operated the planes on any fuel setting other than "both" (though
we filled the tanks with the selector on a single tank to prevent
cross-flow); and I don't recall anyone ever having a fuel starvation
problem.
Maybe it's the notorious Arkansas Triangle?
The placard was found on early model 172s and was there by AD. My
old '59 172 had it. I believe the problem was eventually solved with a
vented fuel cap on the left tank. I don't know if that terminated the
AD or not. My 172 had both the placard and the newer style vented cap
on the left tank.
Old November 23rd 05, 01:30 AM posted to rec.aviation.piloting
Default C-172 Fuel
"John Galban" wrote in message oups.com...
problem.
on the left tank.
Just checked the C-172A fuel selector, and sure enough it says to select a single tank for operation when cruising at
and above 5000'. It also has vented caps on both tanks...
Old November 23rd 05, 03:34 PM posted to rec.aviation.piloting
Default C-172 Fuel
Newps wrote:
(Snip)
Dan, your explanation is theoretically correct, but Newps wrote from
experience. With an incorrectly located vent, and both tanks full, fuel is
forced from left to right. The right tank stays full, and usually dumps
fuel out through the cap, which has a vent that opens both positive and
negative (Monarch caps, at any rate). Ram air pressure continues to force
fuel to the right side, until the left tank empties. The indicator for this
is when the right fuel gauge stays put, and the left goes rapidly toward
empty. Fuel running off the right flap in flight is another hint.
That's how my 182 managed to "burn" 32 gallons/hr on one leg of a long
trip.
Cessna fixed the problem in later years by adding a vent behind the right
strut. For the single vent planes, the location is so critical that it is
specified to the hundredth of an inch. That precision is related to
airflow, not ice.
Old November 23rd 05, 04:37 PM posted to rec.aviation.piloting
Default C-172 Fuel
I have been maintaining Cessnas for ten years now, and the
proper Cessna cap will not allow air out of the tank. By law, an owner
MUST use parts as per Cessna parts manuals, and any other cap that
isn't PMA'd for that airplane is illegal. There is no way that the
airplane is legal if it's doing that, since it doen't comply with the
manuals.
Dan
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
