![]() H_Zwakenberg wrote: Hi Group, if you're building your own plane AND you're thinking of installing anything but a direct drive engine prop/engine system (i.e. a redrive, drive train, whatever), I urge you to read on: Donald P. Hessenaur - an engineer who worked at companies like Bede, RotorWay, Avian and others - wrote a paper about 'Propeller Drive Systems and Torsional Vibration'. This paper influenced my thinking about what engine/prop choices I have for my RJ.03 IBIS homebuilt aircraft project in a major way. snip Download it, read it, study it. Be informed! For my canard project, I've decided to go for a direct drive solution. If you want the "proven solution" buy a direct drive air cooled aircraft engine with its lawn tractor ignition and induction-attached to a production aluminum or tube-and-rag airframe. If you want to experiment, why experiment with unconventional airframe designs when airframes are way ahead of propulsion systems in this market? We have a conucopia of flying airframe designs to suit most all buyers but relatively few powerplant choices with any substantial demonstrated success rates. In another few years,European autoderivative and other diesels will kill the LyCon export business completely, and third parties will be undercutting Lycoming on parts so badly that Lycoming is probably going to die. The Europeans will probably continue the PFM tradition of not selling to homebuilders. As far as I am concerned there are only two possible powerplants for homebuilts, autoderivative engines with US-based parts support, and the P&WC PT-6 series of turboprops. The Allison 250 I tend to discount because the main versions available tend to be helo variants and making them work in a fixed wing aircraft requires what Soloy did-and Soloy is not in the homebuilt business either. The 331 Garrett and the J-69/Turbomeca centrifugal flow turbojet (Marbore??) are too loud to be allowed on civilian ramps as far as I am concerned. Make no mistake, I will shed no tears at the boarded up windows at 651 Oliver Street. |
light twins? | Bellsouth News Server | Home Built | 83 | August 12th 05 02:56 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Torsional Vibration Testing | B2431 | Home Built | 8 | July 25th 03 07:15 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
