First, let me say thank you to everyone who congratulated me!
For those that said that the Instrument is supposed to be harder than the Private, I would probably say that for me it was probably not so much harder, but it presented a very different set of challenges than the Private. Quite frankly, I can see where a VFR pilot, having just gotten his ticket, might have a lot of trouble jumping into the IFR training. But I started my IFR training when I went for my first BFR. So I had been flying for 2 years VFR, and had about 200 hours. Most of my flying has been to make sales and service calls to my computer software business customers ranging from 100NM to 300NM, generally with Flight Following. So I had a fair amount of experience holding the plane steady, learning to trim, and talking to ATC, and letting a lot of this become "second nature". These are some very important IFR flight skills, and by having the experience I had, I was able to get a "head start" on the training. It also gave me the ability to have some fun flying with my eyes out the window for a while before I got under the hood. Another factor for me was my motivation. Cancelling for weather when it was not that bad, but not comfortable for a VFR X-C made it difficult to commit to meetings with any level of certainty. For example, I cancelled a flight from HPN (NY) to ERI(PA) over the Pocono and Allegheny Mountains when the ceilings were 2000'. There aren't any great weather-supplying airports in some of the mountainous areas, and with ceilings that low, I just didn't feel comfortable that I might not have IMC in some of the mountainous areas in between... Now (while there are still obviously weather issues that have to be dealt with - like Ice & T-Storms) if it's just a could deck, I can climb up to VFR on top and know I will be able to get down afterword or even fly through it a while, and that is a wonderful thought. Now I will give you some of the CheckRide Rundown, although I may skip some of the less interesting details... The Oral was simpler than I expected. My mind spent the morning playing games on me - thinking about all the things that I couldn't remember. So I was fairly nervous. The DE was friendly and fairly social, but I was still nervous... As we sat down, the DE covered the basics, starting with the flight planning. He didn't really give me any big surprises at first, so I started to build a little bit more confidence. And most of the discussion was more social than grilling - talking about the rules, but also about the common- sense reasons behind some of the decisions that I had or would make based on scenarios. And of course in many cases talking about the big picture helped demonstrate that I understood, for example, how systems worked even in the discussion of flight planning and weather. As I started to get comfortable, though, he did start to push a bit with a couple of interesting questions that he admitted later he didn't expect me to know answers to. The one that surprised me the most was "Say you let your currency lapse, and now it's a year later and you want to get an IPC. How would you know what you have to show the instructor in order to get signed off?" Of course, I thought it was in the same FAR that talked about currency and the IPC in the first place. Interestingly enough, that wasn't even close. I am going to save the answer for those people who want to work it out on their own... Although after thinking about it, it's not nearly as surprising an answer now that I know where to find it! ![]() So then I go preflight the plane and we get ready to go. When I had flown in to see him, the wind was fairly calm. But by the time we started out, the wind had actually picked up a bit, and changed direction fairly significantly on our flight path. I have to say, it was pretty route, and not very surprising. He played Clearance-Delivery, which admittedly threw me off just a hair... Then we took off and started with some basic VOR tracking and navigation. He had my fly to HTO, the IAF on the VOR approach to the airport of the same name (East Hampton). The wind picked up a bit and changed direction on me, so I kinda blew the correction in the hold/procedure turn (nerves didn't help me much either). I'm not sure if I was asleep at the wheel or if the wind was just squirrely, but basically the inbound leg was not existent and I ended up falling behind it a bit and missing the FAF for about 10-15 seconds and was still not properly corrected. I was pretty embarassed at how poorly I was handling it. I did the Missed Approach, and dealt with it, but now I was even more nervous because I felt that my performance was worse than anything I had done since early training. I thought I was failing. So we flew back to the other airport, and I was having a little bit of trouble tracking on the way back between the squirrely winds and my increased tension and nerves now. At one point he made a comment about it, which in hindsight was probably just meant to help me, but made me even more sure I was failing. Then he vectored me to West, and asked me to do the steep turns. I must say, I thought I did those fairly flawlessly, and that gave me a bit of confidence back. Then he covered the AI and DG, and we started back. He asked me to do the VOR approach into HWV, and somehow I couldn't find the plate - it must have fallen out or something. Back comes all the nervous tension... So he saw that the plate I had on the top of the deck was the GPS approach, and said let's just do that one, starting at one of the intersections. So I programmed it in, and the GPS starts acting weird. What I realized later was that when he asked me to start the approach (or by the time I selected it in, anyway) we were basically right across that intersection, so the GPS flipped me back around. I was starting to freak out and screw around with the OBS until I figured out what was going on. And started to feel worse again. Then I flew the approach. I flew that one fairly well, and then shot the missed. Then he took off the covers, and we went back for the ILS to landing. But all of a sudden the pattern got really busy... So he had me use Pattern Altitude as my MDA and that was a little bit unusual, but I dealt with it. To be honest, it made it feel like it wasn't a complete approach, and I figured he did it because he already knew he was failing me anyway. We went into his office and I apologized for my poor performance. I described to him what I knew that I did wrong - from the things I noted above, to not checking for weather before shooting the approaches, and omitting a couple of radio calls. He pointed out that there were a few things that I handled fairly well that he's seen other students and applicants just "lose it" and give up. He said I handled the mistake on the first approach properly, and even commended for catching the GPS thing because he said even he wasn't quite sure where we were when he cleared me and so it was kinda tricky. He reminded me that in real life, I would have been way out and setting up and it would have been a nonissue. So I walked away with a new rating. And the next day I flew to Wings for a sales call in beautiful CAVU weather! And even though I could have flown VFR, I filed and even got to fly through a cloud! What a rush!!! "Jim" wrote in : CONGRATS!!! How about a run down on the check ride? |
Judah wrote:
So I walked away with a new rating. Very cool! That makes me feel a lot better about my eventual IR checkride (I'm just studying for the written now). I have a lot of confidence - that my performance will be less than perfect! ![]() Thanks for sharing that! |
Very glad I could give you some reassurance! Good luck!
"John Harlow" wrote in : Judah wrote: So I walked away with a new rating. Very cool! That makes me feel a lot better about my eventual IR checkride (I'm just studying for the written now). I have a lot of confidence - that my performance will be less than perfect! ![]() Thanks for sharing that! |
Judah wrote:
Very glad I could give you some reassurance! Good luck! I'd recommend screwing up as early as possible. My first approach was a VOR-A. The PT involves a hold, and the DE had me hold there for a turn or three. It was the worse entry, and the worse hold, I've ever seen. But I managed to stay on the proper side (somehow!) and then completed the approach well. But that hold was so painful, and so terrible...that I realized that I couldn't do any worse. And if I'd not failed at that point... So I recommend an early screwup. It makes for a more comfortable ride laugh. - Andrew |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
Passed my IFR checkride today. | [email protected] | Instrument Flight Rules | 5 | February 8th 04 07:04 AM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 12th 03 12:25 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
