Propeller thrust question
Old November 24th 05, 05:57 PM posted to rec.aviation.piloting
Default Propeller thrust question
"xerj" wrote:
Thrust from a propeller drops as speed increases to a theoretical zero. When
this happens, what is providing the thrust to overcome drag? The forward
momentum of the aircraft?
If so, is it a case of the speed very slightly and imperceptibly dipping
below the zero thrust speed, getting a little thrust to bring it back to the
zero-thrust condition and doing this over and over again?
Thanks in advance.
On a reciprocating engine, you have only so much power available. In
level flight:
Power = Thrust * Velocity. Or: Thrust = Power/Velocity.
If you go faster, thrust decreases to meet power. Thrust, theoretically,
will not go to zero, but will equal drag, which increases with the
square of velocity.
If you dive, thrust is added by the weight of the aircraft * sine of the
dive angle.
Remve "_" from email to reply to me personally.
Static thrust for Sonex with 54" prop Mel Home Built 3 November 2nd 05 12:31 AM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
turbine propeller sebastian Home Built 19 March 21st 04 12:47 AM
