On Sat, 26 Nov 2005 16:10:24 +0000, Peter
wrote: In which case, what could be the sanction if an original was not on board? (Forget the case of the French Customs for the moment; they are a law unto themselves). In the US they would notify you of the alleged violation, give you a chance to respond, and assuming you were found responsible they would then impose whatever legal sanction is available to them for violations 61.3 or 91.203(2). If an original is required (and it appears to me that it is), carrying around a copy is the same as not having it "in that person's physical possession or readily accessible in the aircraft when exercising the privileges of that pilot certificate or authorization", or WRT the registration/airworthiness certificates, "displayed at the cabin or cockpit entrance so that it is legible to passengers or crew." They would end up either suspending for some length of time, or revoking your certificate(s) depending on whatever other factors surround the incident and your enforcement record. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
