![]() "Morgans" wrote in message ... "Peter Dohm" wrote P.S.: I really think that you are giving up a lot of your maximum power in slowing a Soob down enough to drive a propeller at 1:1. What you say about the shaft extension I don't think is applicable to the question of a long drive shaft, which is what the post is asking. (I think) The short extensions you propose (as working for Steve W.) are not long enough to give a problem with resonance, like a long shaft would have. The shorter the shaft, the higher the resonant frequency would be. You are correct about the Soob giving up a lot of power at a 1:1 drive ratio. It depends if the OP is willing to have that much weight for the power being produced. -- Jim in NC There is some question in my mind as to "how long is long", and suggest that Steve Wittman's designs would qualify as long when viewed as prop extensions. However, I agree with you that they are short in the context of driveshafts. With that in mind, a look at Molt Taylor's work (as suggested earlier in this thread) would be a very sound idea. I don't think that there is any resonant frequency that would be acceptable if not damped, although I have been told that any resonant frequency lower than the frequency of the exciting source is usually trivial. I don't know, as it is not my field. Additional sources on information might include any treatise on helicopter tail rotor drives. And, of course, the original post did not mention what was to be on the other end of the driveshaft: prop, clutch, fluid coupling, reduction and/or angle drive, ducted fan, etc... Peter |
Thrust vs Shaft Horse Power? | Evan Williams | Military Aviation | 9 | July 22nd 04 02:45 AM |
Lubricating the primer shaft | Michael Horowitz | Home Built | 9 | November 20th 03 12:26 AM |
Timing on Subaru EJ22 ??? | Randy | Rotorcraft | 1 | November 9th 03 06:15 AM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
What ever happened to the Subaru x-100 ? | Wooduuuward | Home Built | 0 | July 6th 03 12:53 AM |
