![]() "Al" wrote I had an waiver to go to 150' on a cat 1 approach for fog seeding. (We poured a 1 pound coofee can Is that anything like a coffee can? :-)) Really though, that sounds very interesting. What were the results of the testing? Are tests still going on anywhere? Tell us more! -- Jim in NC |
He he, you are right. It was very similar to a "Coffee" can, Folgers in
fact. In Medford, Oregon, in the '70's and '80's, we flew fog seeding for United Airlines. Equipment was a older C-182 with an inspection plate removed in the center of the rear seat floor. We would grind up 15-20 lbs of dry ice, and on repeated passes, pour 1 coffee can worth out the hole through a dish pan, during a low approach. (The approaches were flown both ways, front course to 150', climb to 800 agl, do a 90-270, and fly the backcourse with no GS to 150' on the way back. Localizer flag indicated the end of the runway). If the conditions were right, we had great success. The fog had to be between 33 and about 25 degrees for good results. We would seed for 20 minutes, wait for 20 minutes, and see results for about 20 minutes. (Later known as the Bill Warren 20-20 rule of fog seeding) After 20 minutes of seeding, (3-4 passes), it would snow on the ground for about 20 min. and the visibility would improve. It was not uncommon to go from ceiling of 0 and an RVR of less than 600 to 300 overcast and 1 mile. These results were very local, just before you arrived at DH, you would bust into this "Clear weather tube", the length of the runway. This was "fascinating" flying. The first United flight in the morning was due at 06:15, so one had to start seeding around 5:00. This, of course, meant solid IFR at low altitude, at night, in a single engine airplane, in icing conditions. With each pass, we would climb to VFR conditions, where the temps were a lot higher, and burn off the Ice. I only did it for a year, but there were pilots there like Bill, and George DiMartini that had done it for years. Once on a training flight, I pulled an engine on George who calmly shot a "No visibility" ILS to touchdown, deadstick. I always felt more "lost" on the ground. After loading the aircraft, I would start it, turn on the baggage light under the left wing, and put the left main tire on the yellow taxi stripe. I would taxi out to the hold short line, and shut it down for a minute while I climbed out and broke off the 3/4 inch of ice the prop had built up during taxi. Re-enter, re-start, and taxi on a heading of 90 until the localizer for rwy32 centered, then a left turn to 320, and depart. Total pay was $15 per flight hour, so if you got 1 1/2 hours in the morning, and the same in the evening(6:30pm departure), you could make almost $50 a day before taxes. Instrument currency was never a problem, and you got REALLY good at holding a heading. Sometimes it almost seemed like a video game, or simulator. Once I had done the twenty minutes of seeding, and the RVR was very slow coming up. United was 30 North, so I decided to shorten my pattern, and drop a load right over the RVR meter. After making a pass southbound, I started a left turn toward the RVR meter and simply forgot to climb. Apparently there is a hill called "Coker Butte" just east of the runway at Medford. It is about 100' high, and passed under my left wing while I was in the turn. It has a white house with a yellow bug light on the porch. There was a white 63-64 Chev Impala parked in the driveway under the bug light, it had current Oregon plates. Al "Morgans" wrote in message ... "Al" wrote I had an waiver to go to 150' on a cat 1 approach for fog seeding. (We poured a 1 pound coofee can Is that anything like a coffee can? :-)) Really though, that sounds very interesting. What were the results of the testing? Are tests still going on anywhere? Tell us more! -- Jim in NC |
![]() "Al" wrote Apparently there is a hill called "Coker Butte" just east of the runway at Medford. It is about 100' high, and passed under my left wing while I was in the turn. It has a white house with a yellow bug light on the porch. There was a white 63-64 Chev Impala parked in the driveway under the bug light, it had current Oregon plates. That story belongs in the big scare thread! Is the procedure still widely used today? -- Jim in NC |
