On 28 Nov 2005 10:44:51 -0800, "M.E. Borner"
wrote: My Seneca V (Continental TSIO-360-RB) has been very hard to start during cold weather for the past few winters I have owned it. Besides burning out several starters I have tried tune-ups prior to winter and installing the Slick Shower of Sparks ignition system. All have helped a little but no dramatic improvements. My mechanic has been researching this issue (he also has another Seneca V o nthe field with similar problems) and has come up with a somewhat obscure Continental Service Instruction Letter that references cold weather starting and discusses New Cylinder/Induction Port Drain Connections. This involves 24 new drains ($200 ea.) and before I make an investment on such a vague SIL I thought I would seek others experience. Is anyone familiar with this and care to share experience? I'm thinking that your Seneca V's TCM engine has a RSA/Bendix injection system instead of the "classic" TCM fuel injection. If it does, it needs to be primed/started like an injected Lycoming. Can I ask how you what procedures you are currently using? TC |
I am not sure what type of injection system I have but it definitely is
fuel injected. I too think (am hoping) it is technique related, certainly the least expensive route to a solution. I am leery of burning up another starter while trouble shooting technique. My un-preheated cold weather/cold engine starting technique is very similar to my warm weather/cold engine technique and is as follows: throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank In warm weather it starts right away. Colder weather takes 4-5 seconds of cranking before it starts. Cold weather takes major cranking and no fuel pump after the first attempt. Sometimes I get it going and sometimes I don't. Both engines are very difficult and uncertain, although the right engine is much more cooperative than the left. |
In article .com,
"M.E. Borner" wrote: I am not sure what type of injection system I have but it definitely is fuel injected. I too think (am hoping) it is technique related, certainly the least expensive route to a solution. I am leery of burning up another starter while trouble shooting technique. My un-preheated cold weather/cold engine starting technique is very similar to my warm weather/cold engine technique and is as follows: throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank In warm weather it starts right away. Colder weather takes 4-5 seconds of cranking before it starts. Cold weather takes major cranking and no fuel pump after the first attempt. Sometimes I get it going and sometimes I don't. Both engines are very difficult and uncertain, although the right engine is much more cooperative than the left. Which priming system? My experience is with the Turbo Arrow IV. There are two different priming system for that engine. |
Dude, the T-Arrow IV left the factory with a Rajay turbo with a bolt
screwed into the tailpipe for pseudo boost control-a V's got an Airesearch turbo with a automatic waste gate. You've got TCM "classic" fuel injection, a V's got RSA/Bendix/Precision Airmotive fuel injection. I don't think that the V's installation has the push-to-prime "cold start kit" as an option... The cold start kit option on your engine was a set of fine-wire sparkplugs and a solenoid valve with a couple extra hard lines that allowed fuel to be sprayed directly into the front end of the LH and RH induction pipes. TCM "classic" injected engines are typically started with the mixture control at "full rich", RSA/Bendix injected engines are typically started with the mixture at ICO. regards; TC |
M.E. Borner wrote:
I am not sure what type of injection system I have but it definitely is fuel injected. I too think (am hoping) it is technique related, certainly the least expensive route to a solution. I am leery of burning up another starter while trouble shooting technique. My un-preheated cold weather/cold engine starting technique is very similar to my warm weather/cold engine technique and is as follows: throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank In warm weather it starts right away. Colder weather takes 4-5 seconds of cranking before it starts. Cold weather takes major cranking and no fuel pump after the first attempt. Sometimes I get it going and sometimes I don't. Both engines are very difficult and uncertain, although the right engine is much more cooperative than the left. I believe you are WAY under-priming your engines, when they are un-preheated. Next time, try: Throttle, Wide Open Mixture, Full Rich Fuel Pump, Prime for 6-10 secs, then Off Throttle to 1/4 inch Crank Be ready to turn the fuel pump back on, if the engine starts to die after it starts, otherwise, just leave it off. As a side note, the older Senecas, with the TCM fuel injection and a Cold Start kit, were unstoppable in the winter. You couldn't *not* start those engines, no matter how cold they got. I don't have any experience with the RSA system mated to a Continental 360, but the above technique works very well on any injected Lycoming I've tried. Happy Flying! Scott Skylane N92054 |
On Tue, 29 Nov 2005 11:47:18 -0900, Scott Skylane
wrote: snip As a side note, the older Senecas, with the TCM fuel injection and a Cold Start kit, were unstoppable in the winter. You couldn't *not* start those engines, no matter how cold they got. I don't have any experience with the RSA system mated to a Continental 360, but the above technique works very well on any injected Lycoming I've tried. Heh. Mash the button until the plenum drains start ****ing blue into the snow and start the mutha up. BTDT. TC |
![]() throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank I agree...you are NOT priming enough. In the cold weather you can prime twice as long as in warm weather or even longer. Also, don't forget that the plugs can ice over (or so I am told) and this will cause the plug not to spark. Old wife's tale? Possibly but it makes sense to me. Kobra |
"Kobra" wrote in message
... throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank I agree...you are NOT priming enough. In the cold weather you can prime twice as long as in warm weather or even longer. Also, don't forget that the plugs can ice over (or so I am told) and this will cause the plug not to spark. Old wife's tale? Possibly but it makes sense to me. Kobra Yea, what he said. If you (the original poster) were as old as me, and had grown up pulling on a manual choke every time you started the car, you would realize that cold engines need a lot more fuel to get started than warm engines. All that automatic, electonic stuff might be nice for emssions and reliability (and keeping me employed) but they do insulate the average person from the mechanics of "how an engine works"... And, no, icing plugs is not an old wives tale. Usually happens when the engine fires only once or twice but doesn't start. -- Capt. Geoffrey Thorpe The Sea Hawk At WowWay D0t Com |
On 29 Nov 2005 05:55:17 -0800, "M.E. Borner"
wrote: throttle open 1/4 inch mixture full rich electric fuel pump/prime on wait a few seconds (2 at the most) crank Definitely not enuff fuel for a cold start. In warm weather it starts right away. Colder weather takes 4-5 seconds of cranking before it starts. Cold weather takes major cranking and no fuel pump after the first attempt. Sometimes I get it going and sometimes I don't. Both engines are very difficult and uncertain, although the right engine is much more cooperative than the left. What does "the book" say for a cold start? I learned to verify power and mixture levers aft, boost pump on, power & mixture full forward for 2-3 (or 3-4) seconds, pull back. Crack the throttle, crank the engine, apply mixture lever as needed once the engine starts running. Was taught never to crank an RSA engine with the mixture out of ICO. If it's colder, the levers need to stay ahead longer. The trick is to get it rich enuff to fire, but not excessively rich. If it doesn't fire almost immediately, or fires and dies, you just need to add a little more fuel. If you flood it, you're screwed. You just need to figure out how much fuel your particular pair of engines need to start with varying OAT's TC |
You just need to figure out how much fuel your particular pair of engines need to start with varying OAT's TC TC makes a very important point that is often overlooked when training pilots. I usually start by asking a student what they think happens with the density altitude is when it's cold, then I ask them what that does to their fuel/air mixture. Next question is, if you've got more air, don't you need more fuel? It's amazing how many show surprise. Same theory, opposite actions for hot temps and hot starts. Jim |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
