Hard Starting Cold Continental Engines
Old December 5th 05, 01:51 AM posted to rec.aviation.owning
Default Hard Starting Cold Continental Engines
M.E. Borner wrote:
My un-preheated cold weather/cold engine starting technique is very
similar to my warm weather/cold engine technique
You might want to consider investing a (relatively) small amount of
money in a Tanis heating system. The cost of overhauling those two
engines, including removal, shipping, and reinstallation, would get you
a good way towards buying a house in some of the poorer states, so a
couple of thousand (including labour) for a heating system and
insulated covers would be a wise investment.
If you don't have access to electricity, is there a Herman Nelson or
similar force-air preheater somewhere on your field? If not, perhaps
there are small, portable, propane-powered forced-air heaters you could
buy and bring out with you (I haven't investigated this, since I keep
my plane at a major airport with lots of services).
When you're visiting a remote airport, you can always cover the engines
after a flight -- they should stay warm for quite a few hours under an
insulated cover.
I have to admit that I've cold-started the O-320 on my Warrior down to
-15 degC (with a *lot* of priming), but I'm not proud of it. Now, with
a newly-overhauled engine, I've moved to a spot where I can leave my
Tanis plugging in all winter to protect the investment.
Best of luck,
David
Old December 5th 05, 04:34 AM posted to rec.aviation.owning
I won't start my 172M without preheat unless it is above 40 degF or has
been running recently - and that's with the multivis Aeroshell.
Lycomings are unusually sensitive to cold start cam damage. My
thinking is that even a single episode can create internal mayhem.
Old December 5th 05, 02:11 PM posted to rec.aviation.owning
Perhaps my description was not clear enough. My engines do have Tanis
preheaters on them. When I preheat the engine everything is fine, it
starts like a mid-summer day. The problem is when it is cold and I am
unable to preheat due to lack of accessibility to electricity.
Old December 5th 05, 08:41 PM posted to rec.aviation.owning
It might be worth trying to find some other way to preheat when you
cannot plug in (get the plane pulled into a heated hangar, or borrow a
forced-air heater). Your engines might be trying to send you a
message.
All the best,
David
Old December 6th 05, 04:13 AM posted to rec.aviation.owning
Portable generator?
"M.E. Borner" wrote in message
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
