Reasoning behind course reversal
Old February 18th 04, 08:32 PM
Michael 182
Default Reasoning behind course reversal
What is the reasoning behind the required course reversal in many
approaches? It's hard to believe that I will be safer flying the racetrack
and then the approach to the runway than simply flying to the IAF and
proceeding inbound - especially with GPS guidance. I have no problem flying
the full published course, done it many times, I'm just curious why they are
designed that way.
Michael
Old February 18th 04, 08:48 PM
John R Weiss
"Michael 182" wrote...
designed that way.
Many are for altitude loss. Terrain outside the IAF may prohibit lower altitude
until established on the Approach, and min IAF altitude is too high for a
reasonable descent.
Unless it's a GPS approach, the procedure was not designed for GPS guidance, and
must be designed with all the TERPS constraints in mind.
Old February 18th 04, 08:50 PM
Michael 182
OK, this makes sense, especially since most of the ones I fly are along the
Colorado Front Range. Assuming you were coming in from the west I can see
how the course reversal would give you a protected space to descend in.
Thanks,
Michael
"John R Weiss" wrote in message
news:bcQYb.7844$4o.29910@attbi_s52...
racetrack
flying
are
designed that way.
altitude
reasonable descent.
guidance, and
Old February 18th 04, 09:30 PM
Rick Glasser
designed that way.
Michael
It is also to allow you to get "established" and stabilized on the inbound
course prior to the FAF, especially where the IAF and FAF are the same.
If you just turned inbound at the fix, precious distance would be wasted
while still getting established and technically you should not be
descending until established.
Rick/JYO
PP-ASEL-IA
remove 'nospam' to reply
Old February 18th 04, 11:38 PM
Michael 182
"Rick Glasser" wrote in message
news
racetrack
flying
are
designed that way.
Michael
I know this is what is often written but I think this only argues for an
optional run around the racetrack, not a mandatory turn, or an instruction
on the approach that requires the course reversal if crossing the IAF above
XX altitude. Does that make sense?
Michael
Old February 19th 04, 04:09 AM
Andrew Sarangan
When a single fix doubles as the IAF and the FAF, a PT will be
required. The reason is, an aircraft could be approaching the IAF from
any direction, and you need to maneuver in order to get established on
the final approach course prior to reaching the FAF. When two fixes
are available for an approach, that is when you are likely to find a
NoPT. GPS approaches rarely have PT because you can place a fix almost
anywhere.
"Michael 182" wrote in message news:qZPYb.7436$Xp.59196@attbi_s54...
designed that way.
Michael
Old February 19th 04, 12:27 PM
Ron Rosenfeld
On Wed, 18 Feb 2004 20:32:22 GMT, "Michael 182"
designed that way.
Michael
Michael,
Others have given you some good answers. However, the reasoning often
depends on the particular approach. So it would be useful if you could
post a reference to a procedure about which you have a question.
Old February 19th 04, 04:38 PM
Michael 182
Well, as an example, the BJC ILS 29R. In this case ALIKE is both the IAF and
the FF. Clearly if you are coming in from the west or southeast quadrants,
the course reversal is needed to lose altitude, as John pointed out. Also,
as Andrew pointed out, even if the approach was in Kansas, you migt be
approaching on a 090 heading to a final approach course of 293, and hence
the course reversal makes sense. I guess my question is why not have a
conditional, say if approaching with heading 270 - 330 at altitude of 7300,
no PT required.
I'm not trying to be arugmentative - I just think the procedure turn, in
IMC, may cause more danger than it allieves. On the other hand the
conditional may complicate the instruction - conditionals always provide
more opportunity for error.
Michael
"Ron Rosenfeld" wrote in message
racetrack
flying
are
designed that way.
Michael
Michael,
Old February 19th 04, 05:53 PM
Bob Gardner
Why would a maneuver in protected airspace, sterilized against other IFR
(and VFR talking to ATC) airplanes be dangerous?
Bob Gardner
news:4E5Zb.78441$uV3.535345@attbi_s51...
and
Also,
7300,
no PT required.
Michael
racetrack
flying
they
are
designed that way.
Michael
Michael,
Old February 19th 04, 05:57 PM
Michael 182
I think I said " I just think the procedure turn, in IMC, may cause more
danger than it allieves". I don't think the turn is dangerous per se, but an
approach directly to the FF and inbound, with no dramatic changes in
altitude and direction, seems less dangerous than the same approach with the
addition of a run around the racetrack.
Michael
"Bob Gardner" wrote in message
news:jK6Zb.359414$na.536935@attbi_s04...
Bob Gardner
Complete Reversal or Not? Greg Esres Instrument Flight Rules 10 February 12th 04 10:05 AM
