"john smith" wrote
John, which engine on the Seneca drives the hydraulic pump? The electric one bolted to the top of the powerpack-think Meyer snow plow. (Sound of Homer Simpson "dope slap") Can you tell I'm not a multi-pilot? :-)) Don't feel bad, it's the left engine on our Aztec, no electric hyd pump. Now... along those lines... what would cause a sudden "over flow puddle" from our Aztec's hyd system? Plane's annual was this summer, hyd system topped off with fluid, we've flown it about 40 hours since then. Saturday, the engines were due for fresh oil and filters so I took her out for a short joy ride to warm everything up. Changed the oil and filters but didn't have a chance to pull it back out and do a run up to check for leaks. So last night I go up to the hanger to do that and I notice a puddle of hyd fluid directly below the overflow tube near the rear of the nose gear wheel well. The drop hanging from the overflow tube confirmed where it was coming from, nothing else wet or washed off, but why? why after 40 hours of flying and probably a dozen gear/flap extensions and retractions would it decide to overflow any excess fluid at this time?? I was able to add about 6-8 oz of fluid to the system to top it off. Ran the flaps up and down, no leaks noticed anywhere, no additional overflow out the overflow tube. System fill tube stayed full. Any ideas??? TC what ya think?? Thanks Jim |
I think that raising and lowering a rubber hose to blindly
service/verify the proper level in a power pack reservoir is really goofy. Not sure if that's how yours works or not, but on the newer models the hose was clipped to the side of the nose. In the past, whenever I serviced an Aztruck pack, it would typically vent some on it's first or second (or third) flight, but it never appeared to be very much. I guess I would keep an eye on it to make sure that it isn't still venting, or if it does drip a little more, make sure that it stops after it decides it's at the proper level. TC |
service/verify the proper level in a power pack reservoir is really goofy. Not sure if that's how yours works or not, but on the newer models the hose was clipped to the side of the nose. Goofy. Ditto. Raise it, fill it, lower it, check it, raise it, add some more, lower it. Clip it back in place. Goofy. In the past, whenever I serviced an Aztruck pack, it would typically vent some on it's first or second (or third) flight, but it never appeared to be very much. The puddle seemed to be about two tablespoons full I would guess. Created a stain about 6" dia. I guess I would keep an eye on it to make sure that it isn't still venting, or if it does drip a little more, make sure that it stops after it decides it's at the proper level. Present course of action. Plane's leaving for a 4 day trip this weekend. It's topped off now and we'll see what it looks like when it comes back. Thanks as always. Jim |
On Tue, 29 Nov 2005 13:16:25 -0600, "Jim Burns"
wrote: Goofy. Ditto. Raise it, fill it, lower it, check it, raise it, add some more, lower it. Clip it back in place. Goofy. The only one I've come across that is goofier was the old Navajos. The powerpack fill pipe was hooked to the side of the brake reservoir. You over-filled the brake reservoir until it ran into the power pack. Another goofy thing about this system (which carried through on the newer models) was the screw-down Thermos-type combination stopper/dipstick. Was mounted under a little flapper door on the top of the nose. The "rubber" on the stopper was semi-incompatible with 5606, and usually leaked. Depending on the amount of precipitation present, water would run under the door, around the stopper and into the reservoir. This wasn't typically a problem until winter, when the globs of water would freeze in the lines, either rendering some/all of the brake system inop, or trapping pressure in the lines-locking some/all of the brakes. Had most of the line guys trained to crack the bleeders and shove the !@$% thing into the hangar to thaw out when it happened when I wasn't around. In the past, whenever I serviced an Aztruck pack, it would typically vent some on it's first or second (or third) flight, but it never appeared to be very much. The puddle seemed to be about two tablespoons full I would guess. Created a stain about 6" dia. Sounds familiar. I guess I would keep an eye on it to make sure that it isn't still venting, or if it does drip a little more, make sure that it stops after it decides it's at the proper level. Present course of action. Plane's leaving for a 4 day trip this weekend. It's topped off now and we'll see what it looks like when it comes back. Good deal. Thanks as always. My pleasure. TC |
Gear Warning | Gadget Guy | Soaring | 118 | November 30th 05 10:43 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
