On Wed, 18 Feb 2004 20:32:22 GMT, "Michael 182"
wrote: What is the reasoning behind the required course reversal in many approaches? It's hard to believe that I will be safer flying the racetrack and then the approach to the runway than simply flying to the IAF and proceeding inbound - especially with GPS guidance. I have no problem flying the full published course, done it many times, I'm just curious why they are designed that way. Michael Michael, Others have given you some good answers. However, the reasoning often depends on the particular approach. So it would be useful if you could post a reference to a procedure about which you have a question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Well, as an example, the BJC ILS 29R. In this case ALIKE is both the IAF and
the FF. Clearly if you are coming in from the west or southeast quadrants, the course reversal is needed to lose altitude, as John pointed out. Also, as Andrew pointed out, even if the approach was in Kansas, you migt be approaching on a 090 heading to a final approach course of 293, and hence the course reversal makes sense. I guess my question is why not have a conditional, say if approaching with heading 270 - 330 at altitude of 7300, no PT required. I'm not trying to be arugmentative - I just think the procedure turn, in IMC, may cause more danger than it allieves. On the other hand the conditional may complicate the instruction - conditionals always provide more opportunity for error. Michael "Ron Rosenfeld" wrote in message ... On Wed, 18 Feb 2004 20:32:22 GMT, "Michael 182" wrote: What is the reasoning behind the required course reversal in many approaches? It's hard to believe that I will be safer flying the racetrack and then the approach to the runway than simply flying to the IAF and proceeding inbound - especially with GPS guidance. I have no problem flying the full published course, done it many times, I'm just curious why they are designed that way. Michael Michael, Others have given you some good answers. However, the reasoning often depends on the particular approach. So it would be useful if you could post a reference to a procedure about which you have a question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Why would a maneuver in protected airspace, sterilized against other IFR
(and VFR talking to ATC) airplanes be dangerous? Bob Gardner "Michael 182" wrote in message news:4E5Zb.78441$uV3.535345@attbi_s51... Well, as an example, the BJC ILS 29R. In this case ALIKE is both the IAF and the FF. Clearly if you are coming in from the west or southeast quadrants, the course reversal is needed to lose altitude, as John pointed out. Also, as Andrew pointed out, even if the approach was in Kansas, you migt be approaching on a 090 heading to a final approach course of 293, and hence the course reversal makes sense. I guess my question is why not have a conditional, say if approaching with heading 270 - 330 at altitude of 7300, no PT required. I'm not trying to be arugmentative - I just think the procedure turn, in IMC, may cause more danger than it allieves. On the other hand the conditional may complicate the instruction - conditionals always provide more opportunity for error. Michael "Ron Rosenfeld" wrote in message ... On Wed, 18 Feb 2004 20:32:22 GMT, "Michael 182" wrote: What is the reasoning behind the required course reversal in many approaches? It's hard to believe that I will be safer flying the racetrack and then the approach to the runway than simply flying to the IAF and proceeding inbound - especially with GPS guidance. I have no problem flying the full published course, done it many times, I'm just curious why they are designed that way. Michael Michael, Others have given you some good answers. However, the reasoning often depends on the particular approach. So it would be useful if you could post a reference to a procedure about which you have a question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I think I said " I just think the procedure turn, in IMC, may cause more
danger than it allieves". I don't think the turn is dangerous per se, but an approach directly to the FF and inbound, with no dramatic changes in altitude and direction, seems less dangerous than the same approach with the addition of a run around the racetrack. Michael "Bob Gardner" wrote in message news:jK6Zb.359414$na.536935@attbi_s04... Why would a maneuver in protected airspace, sterilized against other IFR (and VFR talking to ATC) airplanes be dangerous? Bob Gardner |
On Thu, 19 Feb 2004 16:38:24 GMT, "Michael 182"
wrote: Well, as an example, the BJC ILS 29R. In this case ALIKE is both the IAF and the FF. Clearly if you are coming in from the west or southeast quadrants, the course reversal is needed to lose altitude, as John pointed out. Also, as Andrew pointed out, even if the approach was in Kansas, you migt be approaching on a 090 heading to a final approach course of 293, and hence the course reversal makes sense. I guess my question is why not have a conditional, say if approaching with heading 270 - 330 at altitude of 7300, no PT required. Now you have to ask yourself how you would navigate to an area South or East of ALIKE at an altitude of 7300'? I'm having to look at a NACO chart, and I'm used to Jepps. But it seems that there is no airway leading to ALIKE. And the MSA for that area is 10500'. If ATC can give you "vectors to final" in that area, then you would not have to do the course reversal (and can't do it without permission). But absent radar vectors, I don't see a charted way to get to ALIKE at an altitude low enough to avoid the course reversal. I'm not trying to be arugmentative - I just think the procedure turn, in IMC, may cause more danger than it allieves. On the other hand the conditional may complicate the instruction - conditionals always provide more opportunity for error. If you feel that procedure turns cause danger, you probably need to practice them. They should be second nature. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Ron Rosenfeld" wrote in message ... On Thu, 19 Feb 2004 16:38:24 GMT, "Michael 182" wrote: Now you have to ask yourself how you would navigate to an area South or East of ALIKE at an altitude of 7300'? I'm having to look at a NACO chart, and I'm used to Jepps. But it seems that there is no airway leading to ALIKE. And the MSA for that area is 10500'. MSA to the NE is 7300. Navigation by GPS. If ATC can give you "vectors to final" in that area, then you would not have to do the course reversal (and can't do it without permission). But absent radar vectors, I don't see a charted way to get to ALIKE at an altitude low enough to avoid the course reversal. If you feel that procedure turns cause danger, you probably need to practice them. They should be second nature. Hard to argue I need more practice since I live in Colorado where we get very little actual and I only fly 100-150 hours or so a year. In fact, I just hired a CFII for some practice (and an IPC) the other day. No argument that more practice and currency would make me a better pilot. Regardless, my point was not that the PT was dangerous, but relative to an almost straight in approach just added some incremental danger, since there is more time spent maneuvering in IMC at a reasonable low altitude. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Fri, 20 Feb 2004 03:04:53 GMT, "Michael 182"
wrote: MSA to the NE is 7300. Navigation by GPS. Hmmm. According to the NACO chart I downloaded from AOPA, it looks as if the MSA is centered on BJC (VORTAC). So if you are NE of ALIKE, and south of the BJC 090° radial, you would be in the 10500 segment. If you have a Jepp chart that shows the MSA centered on ALIKE, we need to report the discrepancy. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
You're right. My mistake.
Michael "Ron Rosenfeld" wrote in message ... On Fri, 20 Feb 2004 03:04:53 GMT, "Michael 182" wrote: MSA to the NE is 7300. Navigation by GPS. Hmmm. According to the NACO chart I downloaded from AOPA, it looks as if the MSA is centered on BJC (VORTAC). So if you are NE of ALIKE, and south of the BJC 090° radial, you would be in the 10500 segment. If you have a Jepp chart that shows the MSA centered on ALIKE, we need to report the discrepancy. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
MSA is not an operational altitude...it is for emergency use only. Read
5-4-5 AIM. Bob Gardner "Michael 182" wrote in message news ![]() "Ron Rosenfeld" wrote in message ... On Thu, 19 Feb 2004 16:38:24 GMT, "Michael 182" wrote: Now you have to ask yourself how you would navigate to an area South or East of ALIKE at an altitude of 7300'? I'm having to look at a NACO chart, and I'm used to Jepps. But it seems that there is no airway leading to ALIKE. And the MSA for that area is 10500'. MSA to the NE is 7300. Navigation by GPS. If ATC can give you "vectors to final" in that area, then you would not have to do the course reversal (and can't do it without permission). But absent radar vectors, I don't see a charted way to get to ALIKE at an altitude low enough to avoid the course reversal. If you feel that procedure turns cause danger, you probably need to practice them. They should be second nature. Hard to argue I need more practice since I live in Colorado where we get very little actual and I only fly 100-150 hours or so a year. In fact, I just hired a CFII for some practice (and an IPC) the other day. No argument that more practice and currency would make me a better pilot. Regardless, my point was not that the PT was dangerous, but relative to an almost straight in approach just added some incremental danger, since there is more time spent maneuvering in IMC at a reasonable low altitude. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Sat, 21 Feb 2004 22:40:09 GMT, "Bob Gardner" wrote:
MSA is not an operational altitude...it is for emergency use only. Read 5-4-5 AIM. Agreed. However, the context of this discussion seems to be pilot-nav random routing and the reason for a procedure turn at this particular approach. It is not a vectors-to-final routing where ATC may assign an altitude. Are you of the opinion that the IFR charts suggest that when on a random route and NE of ALIKE (but south of the BJC 090 radial) that 7300 is a perfectly OK altitude to use? My teaching has been that when not on a "solid black line" or receiving radar vectors from ATC, to not go below the MSA, OROCA, etc., for that area. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Complete Reversal or Not? | Greg Esres | Instrument Flight Rules | 10 | February 12th 04 10:05 AM |
