Saratoga Gear Retract Problem
Old November 29th 05, 03:28 PM posted to rec.aviation.owning
Default Saratoga Gear Retract Problem
"john smith" wrote
John, which engine on the Seneca drives the hydraulic pump?
The electric one bolted to the top of the powerpack-think Meyer snow
plow.
(Sound of Homer Simpson "dope slap")
Can you tell I'm not a multi-pilot? :-))
Don't feel bad, it's the left engine on our Aztec, no electric hyd pump.
Now... along those lines... what would cause a sudden "over flow puddle"
from our Aztec's hyd system? Plane's annual was this summer, hyd system
topped off with fluid, we've flown it about 40 hours since then. Saturday,
the engines were due for fresh oil and filters so I took her out for a short
joy ride to warm everything up. Changed the oil and filters but didn't have
a chance to pull it back out and do a run up to check for leaks. So last
night I go up to the hanger to do that and I notice a puddle of hyd fluid
directly below the overflow tube near the rear of the nose gear wheel well.
The drop hanging from the overflow tube confirmed where it was coming from,
nothing else wet or washed off, but why? why after 40 hours of flying and
probably a dozen gear/flap extensions and retractions would it decide to
overflow any excess fluid at this time??
I was able to add about 6-8 oz of fluid to the system to top it off. Ran
the flaps up and down, no leaks noticed anywhere, no additional overflow out
the overflow tube. System fill tube stayed full.
Any ideas??? TC what ya think??
Thanks
Old November 29th 05, 06:39 PM posted to rec.aviation.owning
I think that raising and lowering a rubber hose to blindly
service/verify the proper level in a power pack reservoir is really
goofy. Not sure if that's how yours works or not, but on the newer
models the hose was clipped to the side of the nose.
In the past, whenever I serviced an Aztruck pack, it would typically
vent some on it's first or second (or third) flight, but it never
appeared to be very much.
I guess I would keep an eye on it to make sure that it isn't still
venting, or if it does drip a little more, make sure that it stops
after it decides it's at the proper level.
TC
Old November 29th 05, 07:07 PM posted to rec.aviation.owning
I do remember it is real costly. My mechanic took out mine and cleaned
it up inside and now it works just fine. So you should look at that
possibility. Lots of things are not repairable, but really are. I do
recall all that troubleshooting cost me close to 3k$.
John
George Sconyers wrote:
Sure hope my problem is the same as yours. I just ordered the $672 switch
from Piper! Hopefully, my mechanic's discount he has setup with them will
bring the price down 30%. Do you remember what you payed for the pressure
limit switch (Piper part number 587-847)?
-George
"The Visitor" wrote in message
I have a seneca 3. My problem started out like that, easy to sort of fly
with. Then it got worse. Sometimes wouldn't at all retract, or just
partially then pump would go off.
We, flushed out and changed fluid, swaped up and down relays(they are the
same), measured pump pressure, changed pump/motor, gear was in no way
binding. The last thing checked was an over pressure limit switch that was
going faulty and shutting the pump off.
2000 Saratoga? Mmmmm, nice.
Our gear is probably similar in design?? Good Luck.
John
Yahoo! News wrote:
During day one of my 2000 Saratoga's annual today my mechanic and I
observed the following problem. If anyone has some experience with this
or they have a mechanic that has experience with this I would love to
hear about it:
Here is a description of what we are observing:
1) Gear retraction is initiated with handle being placed into the
gear up position
2) Nose gear and main gear unlock and start retraction
3) Gear Unsafe light illuminates simultaneously with gear unlocks
4) In about 1-2 seconds, nose gear completes retraction first (this
is normal as far as what I have observed in the past both on my plane on
jacks and on observing others from the ground departing from airports)
5) Main gear comes up part way but hesitates until nose gear
completes retraction - again I believe this is normal
6) Main gear almost completes retraction in about 2 seconds after
nose gear - a few inches from being completely retracted - this is where
something has changed.
7) Pump Motor shuts off for approximately ¼ second
8) Pump Motor starts again for approximately ¼ second and gear
moves up a little more (maybe ½ inch to 1 inch)
9) Pump Motor shuts off again and restarts again 3-5 times in the
same pattern of quick off and ons before gear is completely retracted and
pump motor remains off
10) Gear warning light extinguishes about the time or slightly before
the pump motor shuts off for the last time
This process is very repeatable. Only the number of quick off-on cycles
of the pump varies slightly. The pump almost always remains off for many
minutes once the gear is completely retracted. The gear was left in the
up position for at least 5+ minutes at one point and we did not observe
any restart of the pump. We did observe a quick on-off cycle of the pump
perhaps 5 seconds after retraction during just one of 15-20 retraction
tests performed, but again, normally the pump would shut off after the
last cycle and remain off for many minutes during our testing.
Everything seems normal compared to what I have observed when we did the
annuals before except for the pump cycling off and on near the end of the
main gear retraction cycle. We have studied the hydraulic and electrical
schematics for the system and looks like there is a pressure limit switch
that is responsible for stopping the pump motor when the pressure reaches
approximately 1800 psi. This should occur after all the gear is retracted
and against the physical stops. We are theorizing that this switch or
the contactor that it operates could be faulty and prematurely stopping
the pump prior to the gear being completely retracted. If the switch
opened at a lower pressure for instance or cycled between opened and
closed in a lower pressure range then it was supposed to we are thinking
that the symptoms we are seeing would result. According to the
maintenance manual the switch is supposed to close at 200 to 400 psi and
open at 1800 +/- 100 psi. We have looked all over for anything impeding
the main gear retraction and were not able to identify any hang-ups
there. We have also verified that adequate 5606 is available in the
reservoir of the pump.
Again if anyone has some insights on my gear retract symptoms I would
sure like to hear about it. If you believe our theory about the pressure
limit switch being bad is unlikely and that it would be wiser to go down
another path I would also like to hear about that too. My mechanic and I
will be all over this tomorrow so if you know anything about this post
what you know.
- George
Old November 29th 05, 07:16 PM posted to rec.aviation.owning
Goofy. Ditto. Raise it, fill it, lower it, check it, raise it, add some
more, lower it. Clip it back in place. Goofy.
The puddle seemed to be about two tablespoons full I would guess. Created a
stain about 6" dia.
Present course of action. Plane's leaving for a 4 day trip this weekend.
It's topped off now and we'll see what it looks like when it comes back.
Thanks as always.
Old November 29th 05, 10:29 PM posted to rec.aviation.owning
I paid $550 for a replacement switch for my Seneca1 five years ago. Glad I
had it replaced then. Same part (mfg. by Consolidated Controls)
"George Sconyers" wrote in message
-George
was
John
this
hear about it:
gear up position
(this
on
where
and
cycles
many
pump
electrical
switch
reaches
retracted
thinking
and
impeding
pressure
down
I
what you know.
- George
Old November 29th 05, 11:05 PM posted to rec.aviation.owning
The problem was indeed the pressure sensor switch. Gear retract time is now
3-4 seconds total and smooth.
"Yahoo! News" wrote in message
t...
or they have a mechanic that has experience with this I would love to hear
about it:
gear up position
8) Pump Motor starts again for approximately ¼ second and gear moves
and against the physical stops. We are theorizing that this switch or the
contactor that it operates could be faulty and prematurely stopping the
pump prior to the gear being completely retracted. If the switch opened
at a lower pressure for instance or cycled between opened and closed in a
lower pressure range then it was supposed to we are thinking that the
symptoms we are seeing would result. According to the maintenance manual
the switch is supposed to close at 200 to 400 psi and open at 1800 +/- 100
psi. We have looked all over for anything impeding the main gear
retraction and were not able to identify any hang-ups there. We have also
verified that adequate 5606 is available in the reservoir of the pump.
Again if anyone has some insights on my gear retract symptoms I would sure
like to hear about it. If you believe our theory about the pressure limit
switch being bad is unlikely and that it would be wiser to go down another
path I would also like to hear about that too. My mechanic and I will be
all over this tomorrow so if you know anything about this post what you
know.
- George
Old November 29th 05, 11:17 PM posted to rec.aviation.owning
On Tue, 29 Nov 2005 13:16:25 -0600, "Jim Burns"
The only one I've come across that is goofier was the old Navajos. The
powerpack fill pipe was hooked to the side of the brake reservoir. You
over-filled the brake reservoir until it ran into the power pack.
Another goofy thing about this system (which carried through on the
newer models) was the screw-down Thermos-type combination
stopper/dipstick. Was mounted under a little flapper door on the top
of the nose.
The "rubber" on the stopper was semi-incompatible with 5606, and
usually leaked. Depending on the amount of precipitation present,
water would run under the door, around the stopper and into the
reservoir.
This wasn't typically a problem until winter, when the globs of water
would freeze in the lines, either rendering some/all of the brake
system inop, or trapping pressure in the lines-locking some/all of the
brakes. Had most of the line guys trained to crack the bleeders and
shove the !@$% thing into the hangar to thaw out when it happened when
I wasn't around.
stain about 6" dia.
Sounds familiar.
Good deal.
Thanks as always.
My pleasure.
TC
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
