![]() "Newps" wrote in message ... dlevy wrote: What can go that fast (J) on that fuel burn and have ample used selection? A bonanza? Not for 100k. A Bonanza? Yes. I bought one. My S35, which is the fastest model, cost me $88K this past August. At 75% I indicate 165 Kts and usually true at 172-175 kts. That costs 15 gph. 165 kts true costs 13 gph. 155 kts true costs 11 gph. Want to bust your buddy's in the 182's chops? 19" and 2100 gets me 135 kts IAS on 9 gph. How are you leaning? 1271 useful(with 4 seats in) and a cabin that isn't a tomb to crawl into. Look in Trade A Plane, there's a million of them for sale. From the "Bonanza Guide" , Budd Davisson, Plane and Pilot, February, 2001 S35-1964 A third generation of Bonanza was born with the "S" model because the 0-470 was tossed out in favor of a healthy IO-520 with 285 horses. With this engine, the Bonanza reached it's zenith in terms of power plants until the turbo charged models came along two years later. The "S" also introduced regular seats way back in the rear of the cabin that faced forward. They had messed with an optional 5th seat since the 1961 "N" model, but it was a marginal seat. With the "S" they had real seats back there. With slightly less than 1,400 pounds useful, the airplanes could carry six people and still fill the 50 gallon standard (80 gallons, optional) tanks as long as no one carried any baggage. The "S" also introduced the three-blade prop as an option. Model Year Prices Speed, knots S35 1964 $78,000 178 -285 hp |
Matt Barrow wrote:
"Newps" wrote in message ... A Bonanza? Yes. I bought one. My S35, which is the fastest model, cost me $88K this past August. At 75% I indicate 165 Kts and usually true at 172-175 kts. That costs 15 gph. 165 kts true costs 13 gph. 155 kts true costs 11 gph. Want to bust your buddy's in the 182's chops? 19" and 2100 gets me 135 kts IAS on 9 gph. How are you leaning? I would concur with Newps' numbers. At 75 degrees lean of peak, wide open throttle, and 2500 rpms, my V35B with a turbo-normalized IO-520 will true between 175 and 190kts (altitude depending) and between 15.5 and 16.5 gph (OA temperature depending). 19" and 2200 rpms will also result in similar numbers as his, again keeping mixture LOP. -- Peter |
![]() "Peter R." wrote in message ... Matt Barrow wrote: "Newps" wrote in message ... A Bonanza? Yes. I bought one. My S35, which is the fastest model, cost me $88K this past August. At 75% I indicate 165 Kts and usually true at 172-175 kts. That costs 15 gph. 165 kts true costs 13 gph. 155 kts true costs 11 gph. Want to bust your buddy's in the 182's chops? 19" and 2100 gets me 135 kts IAS on 9 gph. How are you leaning? I would concur with Newps' numbers. I don't disagree; they seem right out of the book. I'm just wondering if he's LOP or ROP. At 75 degrees lean of peak, wide open throttle, and 2500 rpms, my V35B with a turbo-normalized IO-520 will true between 175 and 190kts (altitude depending) and between 15.5 and 16.5 gph (OA temperature depending). WOT, 60 LOP gives me 188kts and 16.4 gph at 12,500 in my TNIO-550 B36, the big difference being that you and are are running TN'ers. 19" and 2200 rpms will also result in similar numbers as his, again keeping mixture LOP. -- Peter |
![]() Matt Barrow wrote: "Newps" wrote in message ... dlevy wrote: What can go that fast (J) on that fuel burn and have ample used selection? A bonanza? Not for 100k. A Bonanza? Yes. I bought one. My S35, which is the fastest model, cost me $88K this past August. At 75% I indicate 165 Kts and usually true at 172-175 kts. That costs 15 gph. 165 kts true costs 13 gph. 155 kts true costs 11 gph. Want to bust your buddy's in the 182's chops? 19" and 2100 gets me 135 kts IAS on 9 gph. How are you leaning? The numbers I listed are right out of the book. I have been experimenting with lean of peak and at the 19"/2100 setting I can get to 8 gph without any roughness and I don't have GAMI's. |
![]() "Newps" wrote in message . .. Matt Barrow wrote: A Bonanza? Yes. I bought one. My S35, which is the fastest model, cost me $88K this past August. At 75% I indicate 165 Kts and usually true at 172-175 kts. That costs 15 gph. 165 kts true costs 13 gph. 155 kts true costs 11 gph. Want to bust your buddy's in the 182's chops? 19" and 2100 gets me 135 kts IAS on 9 gph. How are you leaning? The numbers I listed are right out of the book. I have been experimenting with lean of peak and at the 19"/2100 setting I can get to 8 gph without any roughness and I don't have GAMI's. What are the temps you're getting? At the setting you mention, how much LOP are you? |
![]() Matt Barrow wrote: How are you leaning? The numbers I listed are right out of the book. I have been experimenting with lean of peak and at the 19"/2100 setting I can get to 8 gph without any roughness and I don't have GAMI's. What are the temps you're getting? At the setting you mention, how much LOP are you? I have a single cylinder non digtal EGT gauge, your garden variety Alcor EGT and the standard analog CHT in the cluster. The CHT temp is pretty low, at any power setting. At those power settings maybe 250F. I am running at 50 LOP. |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
that Mooney in DC ADIZ | Cub Driver | Piloting | 10 | November 13th 03 09:15 PM |
