Landing gear - stupid question...
Old November 30th 05, 11:04 PM posted to rec.aviation.soaring
Default Landing gear - stupid question...
Dear Captain Thorpe,
It always a pleasure to talk gliders. The three-wheeled approach is the =
most common in tandem two-seater gliders because it accommodates well =
the large changes in C.G between the empty glider (tailwheel rests =
lightly on the ground, so that raising the tail for ground handling is =
easy) the glider with one occupant (nosewheel rests lightly on the =
ground) and two occupants (nose a little heavier). In any case, the main =
wheel remain at a position that makes rotation at take-off so effortless =
that it almost happens by itself.
A few two seaters have a two-wheel design, that unavoidably makes he =
ground handling and/or the take-off run a little more difficult.
Why do gliders not adopt a classic three-wheel taildragger =
configuration? Because:
a) a semi-recessed wheel close to the fuselage has a much lower drag =
than a wheel dangling away from the fuselage on some kind of support;
b) it is a superbly robust system that can handle landings in soft or =
rocky ground, as cross-country going gliders often must. A conventional =
aircraft would leave its undercarriage (sorry, gear) behind in such =
terrain.
Kind regards,
Titanium landing gear Neal Fulco Home Built 0 June 17th 04 11:11 PM
LS-6a Landing Gear Problem Michael Higgins Soaring 5 June 2nd 04 09:59 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
