My mechanics have replaced all 6 rocker box
covers and gaskets, and re-flared the push rod tubes. I have spent almost $1000.00 so far and it's still leaking. You told your mechanic that you had an oil leak, and that he should go fix it? Whoo-eee...I'll bet he's had visions of sugar plums dancing in his head for weeks! Talk about a license to steal... Never, ever send an A&P on a fishing expedition. You'll only get hooked, and everything will smell fishy... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
covers and gaskets, and re-flared the push rod tubes. I have spent almost $1000.00 so far and it's still leaking. JayYou told your mechanic that you had an oil leak, and that he should go fix it? Whoo-eee...I'll bet he's had visions of sugar plums dancing in his head for weeks! Talk about a license to steal... Not at all. I was there every minute, observing everything. I even flew to Danbury (Coastal Aviation) to pick up the new rocker box covers myself. I did the runups on the ramp after each attempt to fix it. These guys were definitely not trying to exploit me, and they are just as frustrated as me by the persistant leak. In fact, I am forwarding all the comments from the NG to them at their request. They want to fix it as much as I do. Never, ever send an A&P on a fishing expedition. You'll only get hooked, and everything will smell fishy... Sound advice, but this is not the case here. Thanks . . . www.Rosspilot.com |
hooked, and everything will smell fishy... Sound advice, but this is not the case here. Thanks . . . I know you didn't, Lee. I guess I forgot the little smiley thingy... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Small Continentals typically leak from both ends of the pushrod tubes. The rubber couplings at the case need to be replaced, which requires pulling the cylinders off, at which time the cylinder base seals (o-rings) should be done, too. The head end of the tubes will often leak until the rocker covers are removed, cleaning solvent (like Brake and Parts Cleaner or laquer thinner) is used to flush out the tube/head joints, and a wicking Loctite is run into them. If it's the front crankshaft seal, there's a split version available to install without any fuss. The oil tank or accessory cover gaskets might be leaking, and worst of all, the crankcase joint might be starting to seep. Dan |
If the pushrod tubes are the same as on the big bore Continentals then
the cylinders do not need to be pulled, you just need the tool to compress the springs. And no mechanic worth the title uses loctite on those tubes. If you get the gaskets in right they do not leak. Very easy to tell with a little mirror. The O-200/O-300 engines have the pushrod tube swaged into the cyl head assembly. There is an elastomeric seal at the crankcase end only. I understand there is a re-swaging tool that I assume you already have used to tighten these joints, but that tool can only do so much before it damages the tubes etc. The use of loctite is appropriate. I thought someone had mentioned it earlier (maybe on another post?) & I've never tried it, but perhaps you could pressurize the crankcase thru the breather line to maybe 1-2 psi & do soap bubble tests. Don't go any higher or you would probably blow out the front crankshaft seal. BTW I assume the front seal has its split in the correct quadrant? Chances are otherwise pretty good the leak is around one of the case or pan splits, in which case a vaccum should be used to suck in a sealant after cleaning. |
Ignition problem? | nauga | Home Built | 10 | July 1st 04 02:15 AM |
A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 07:59 PM |
Fiberglass Cowl Problem | Boelkowj | Home Built | 6 | December 20th 03 02:08 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
