On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws
wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On 12/3/05 8:07 AM, in article ,
"Ron Rosenfeld" wrote: On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) If the FAA says I can't use a VFR GPS as my primary nav source, that indicates to me that they must have a way of defining it, or at least expect me to be able to, although without telling me how. But I guess I'm expecting logic from a government agency. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com More Cartoons with a Touch of Magic http://www.cartoonclipart.com |
On Sat, 03 Dec 2005 10:20:32 -0500, Wizard of Draws
wrote: ... I guess I'm expecting logic from a government agency. Ah -- there's your error sigh!! "We're from the FAA, and we're not happy until you're not happy!" Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote:
On Fri, 02 Dec 2005 20:59:57 -0500, Wizard of Draws wrote: Enroute, I can't always be sure what would be considered my primary nav source "from an FAA point of view" since I'm using more than one, that's why I started this thread. As I wrote, the FAA doesn't define "primary" in the PC/G and it's not defined in 14 CFR 1.1. If there is a need for you to have a definitive answer, you could try writing the FAA Chief Counsel. But there may be no answer forthcoming unless there is some operational reason to come up with one. And, in the case of a non-commercial Part 91 small aircraft flight, such as it seems you are describing, I don't see an operational reason to answer that question. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) The FAA doesn't need a regultion to set forth policy. The FAA policy remains that VOR is the primary method for domestic en route IFR navigation. This is related to the ICAO definitions of Class I and Class II navigation. |
A Remote Compass- java source | [email protected] | General Aviation | 0 | July 3rd 04 06:39 PM |
Winscore source code now available | Guy Byars | Soaring | 0 | February 5th 04 10:43 AM |
Are handheld GPSes becoming a defacto primary nav source? | Paul Tomblin | Instrument Flight Rules | 44 | September 13th 03 10:36 PM |
OT- north korean nuke weapon plutonium - source? | patrick mitchel | Military Aviation | 11 | August 31st 03 04:01 AM |
Source for copper crush gaskets??? | Jim | Owning | 0 | August 22nd 03 06:31 PM |
