Trouble with AOPA's Real Time Flight Planner
Old December 3rd 05, 03:48 PM posted to rec.aviation.piloting
Default Trouble with AOPA's Real Time Flight Planner
Has anyone else had problems with AOPA's RTFP? Every time I try to connect
to the weather server I get a "Session Completed Prematurely" error.
Old December 3rd 05, 04:11 PM posted to rec.aviation.piloting
Used it a few times with no problems.
Old December 3rd 05, 07:04 PM posted to rec.aviation.piloting
Never had a problem so far.
Tom
Old December 3rd 05, 09:32 PM posted to rec.aviation.piloting
I recalled having similar problem last year while connecting to the
web through an usb modem (Modem blaster V.92). I replaced the modem
with an internal one and the problem went away eventhough the
connection speed was not much different. You may want to access AOPA's
RTFP using another PC or through another internet servr to see if the
problem goes away.
I am now happily surfing the web through Verizon Yahoo DSL at
$14.95/month.
Hai Longworth
Old December 3rd 05, 11:30 PM posted to rec.aviation.piloting
It works OK for me.
John Severyn
KLVK
"Michael Brown" wrote in message
connect to the weather server I get a "Session Completed Prematurely"
error.
Old December 4th 05, 08:27 PM posted to rec.aviation.piloting
The only problem I've had is finding that you can't reverse a route to print
out your return nav log and flight plan if there are any waypoints defined.
AOPA has confirmed that you can't. What's the point in being able to
reverse the route only after you've removed all the waypoints you so
carefully put in? Stupid.
Bob (Chief Pilot, White Knuckle Airways)
"Tom" wrote in message
Tom
Old December 5th 05, 01:51 PM posted to rec.aviation.piloting
Are you using Norton Internet Security or Windows XP personal firewall?
I believe I can help. I had the same issue.
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Flight Test RealAir Griffon Spitfire Dudley Henriques Simulators 1 December 4th 04 11:46 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
