Meigs Field is a man made island created in the 1930s. Who knows where
all the fill came from so it isn't surprising that contamination can be found deep in the soil. Let's be honest. There was a time in the not too distant past where we were not that careful about spills at airports, railroad yards, truck depots, service stations, tank farms, etc. etc. "kontiki" wrote in message ... wrote: The chemicals are the by-product of aircraft emissions, refueling operations, and spills that occurred over 50 years, and they were found up to 9 feet below ground. If you dug down into any number of 50 year-old (or greater) backyards you's probably be shocked at the concotion of contaminats to be found. I would bet any money that the amounts of contaminats from various airports are but a blip in the noise level compared to all the contaminats from homes and businesses across the country. But why inject logic in to the maelstrom. |
![]() "sfb" wrote Let's be honest. There was a time in the not too distant past where we were not that careful about spills at airports, railroad yards, truck depots, service stations, tank farms, etc. etc. Shoot, I've seen grading equipment leaking hydraulic fluid by the gallons, and still keep on working. It could be some of that, too. -- Jim in NC |
![]() Morgans wrote: "sfb" wrote Let's be honest. There was a time in the not too distant past where we were not that careful about spills at airports, railroad yards, truck depots, service stations, tank farms, etc. etc. Shoot, I've seen grading equipment leaking hydraulic fluid by the gallons, and still keep on working. It could be some of that, too. Thats the ticket, it was hydralic fluid from the dozers craving all the XXX's. -- Jim in NC |
On Sun, 4 Dec 2005 01:36:59 -0500, "Morgans"
wrote: "sfb" wrote Let's be honest. There was a time in the not too distant past where we were not that careful about spills at airports, railroad yards, truck depots, service stations, tank farms, etc. etc. Shoot, I've seen grading equipment leaking hydraulic fluid by the gallons, and still keep on working. It could be some of that, too. Leak? I was raided in rural Michigan. In the 40's and 50's they used to *spray* the gravel roads with brine and/or oil. In many places they even used what was affectionately known as "drip". Ever hear a car run on that stuff? :-)) When changing the oil in cars and tractors people were encouraged to spread it on the gravel roads to keep the dust down. The brine truck used to make at least two trips a summer down our road. Most of the foundation for older roads around here has two or three heavy coats of brine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote in message ... On Sun, 4 Dec 2005 01:36:59 -0500, "Morgans" wrote: "sfb" wrote Let's be honest. There was a time in the not too distant past where we were not that careful about spills at airports, railroad yards, truck depots, service stations, tank farms, etc. etc. Shoot, I've seen grading equipment leaking hydraulic fluid by the gallons, and still keep on working. It could be some of that, too. Leak? I was raided in rural Michigan. In the 40's and 50's they used to *spray* the gravel roads with brine and/or oil. In many places they even used what was affectionately known as "drip". Ever hear a car run on that stuff? :-)) When changing the oil in cars and tractors people were encouraged to spread it on the gravel roads to keep the dust down. The brine truck used to make at least two trips a summer down our road. Most of the foundation for older roads around here has two or three heavy coats of brine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com I remember that being done in the '60s and maybe even into the early 70's. They would lay down coat of heavy oil then top it with fine gravel. A poor mans asphalt. |
![]() "Roger" wrote I was raided in rural Michigan. I hope that being "raided" didn't set your development back too far! BFG In the 40's and 50's they used to *spray* the gravel roads with brine and/or oil. I too remember the oil spraying. In many places they even used what was affectionately known as "drip". Ever hear a car run on that stuff? :-)) Now, I'm clueless when you speak of "drip." What is it? When changing the oil in cars and tractors people were encouraged to spread it on the gravel roads to keep the dust down. The brine truck used to make at least two trips a summer down our road. Brine? As in sal****er, or something else? Most of the foundation for older roads around here has two or three heavy coats of brine. That sounds like the tar oil type of stuff, like they still use between coats of bitumenous (sp?) concrete. (asphalt) I'm surprised you know about all of this road stuff. Did they really have cars, back when you grew up? g,dr -- Jim in NC -- Jim in NC |
On Fri, 9 Dec 2005 01:07:38 -0500, "Morgans"
wrote: "Roger" wrote I was raided in rural Michigan. I hope that being "raided" didn't set your development back too far! BFG That happens at 4:00 AM. In the 40's and 50's they used to *spray* the gravel roads with brine and/or oil. I too remember the oil spraying. In many places they even used what was affectionately known as "drip". Ever hear a car run on that stuff? :-)) Now, I'm clueless when you speak of "drip." What is it? The "low boilers" driectly off the oil wells. Lots of Naptha and other good *stuff*. Spark knock like crazy, foul the plugs, backfie through the carb and bark out the exhaust. When times were tough people used to slip up to the tanks and drain off a bit. You could tell by the noise (and smell) who was burning the stuff. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com When changing the oil in cars and tractors people were encouraged to spread it on the gravel roads to keep the dust down. The brine truck used to make at least two trips a summer down our road. Brine? As in sal****er, or something else? Most of the foundation for older roads around here has two or three heavy coats of brine. That sounds like the tar oil type of stuff, like they still use between coats of bitumenous (sp?) concrete. (asphalt) I'm surprised you know about all of this road stuff. Did they really have cars, back when you grew up? g,dr -- Jim in NC |
... Leak? I was raised in rural Michigan. In the 40's and 50's they used to *spray* the gravel roads with brine and/or oil. In many places they even used what was affectionately known as "drip". Ever hear a car run on that stuff? :-)) When changing the oil in cars and tractors people were encouraged to spread it on the gravel roads to keep the dust down. The brine truck used to make at least two trips a summer down our road. Most of the foundation for older roads around here has two or three heavy coats of brine. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger If it weren't for brine, there'd be no Dow and if there were no Dow there'd probably be no Midland. http://www.geo.msu.edu/geo333/dow.html I can still hear my boss's voice on the Corporate History piece we did: "It was in 1897 that Herbert Dow discovered Brine buried in pockets deep beneath the Earth..." Jay Beckman PP-ASEL Chandler, AZ (Production Intern - Dow Chemical Co. PR Dept. Midland, MI - '84/'85) |
![]() "Jay Beckman" wrote If it weren't for brine, there'd be no Dow and if there were no Dow there'd probably be no Midland. Harumph. I had no idea that there was brine in Michigan, and that started Dow. Learn something new every day. Some days. I wouldn't want to be "too" smart. g -- Jim in NC |
"Morgans" wrote in message
... "Jay Beckman" wrote If it weren't for brine, there'd be no Dow and if there were no Dow there'd probably be no Midland. Harumph. I had no idea that there was brine in Michigan, and that started Dow. Learn something new every day. Some days. I wouldn't want to be "too" smart. g -- Jim in NC Little known and lesser cared about trivia ... Probably the only thing I took with me from my short stint in Midland. My internship supervisor was "old school" having worked his way up through the ranks as a "one man band" street reporter shooting stories on 16mm film and was sure I'd never amount to much. 20 years (11 at the network level), 7 Emmy Awards (self agrandizement...sorry), and my PP-ASEL later ... well it just goes to show you never know... LOL! ;O) Jay B |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
