My first big IFR mistake...
Old February 24th 04, 01:21 AM
Mike Rapoport
"Michael" wrote in message
om...
"Mike Rapoport" wrote
Wow! I can't believe all the posts recommending ways of disabling the
ADF!
Why not? Once you buy into the idea that an instrument rating isn't
actually very useful in the sort of airplane he will be flying, and is
just a piece of paper to get, it makes all the sense in the world.
Disabling the ADF makes the piece of paper easier to get.
Depending on where he lives and flys, it could be very useful. I learned to
fly in SoCal where there is a lot of benign IMC. I agree that there are
also some places where IMC can never be flown safely without a lot of
equipment.
Dumbing down the test so that you can pass it is not a good idea and
that
philosophy is not going to make anyone good at anything.
Except passing tests.
I like the idea of using a flightsim to practice.
I do too, especially since you can (a) stop the action to think while
you're coming up to speed and (b) get a track showing what you did
immediately afterwards.
I also think that NDB approaches are the second-best exercise in
situational awareness available - NDB holds are the first. Once
situational awareness is mastered, it actually takes very little time
to learn NDB approaches. Thus my advice is this - focus on knowing
where on the approach plate you are, every minute. Know where the
wind is coming from. It's perfectly legitimate to draw a wind arrow
on the approach plate once you figure out the wind, and it can make
visualizing your correction easier. Remember, the procedure turn is
not cast in stone. You can go more than a minute outbound before
turning 180, and if there's a stiff headwind from that direction you
probably should. How many degrees you should lead your turn onto the
FAC becomes obvious when you keep wind and distance from the beacon in
mind. Keep in mind that heading, bearing (absolute and relative),
course, and track are all different things. Know the differences.
Once you get to that point, you won't need the rules, the mnemonics,
the tricks, or any of the rest of that garbage. The corrections will
become intuitive.
Thus I have a suggestion about the best way to use flight sim. If you
are not sure what the needle is telling you or how to correct, DON'T
GUESS. Stop the action and figure it out, then start again. You will
find that with time, you will not need to stop anymore. At that
point, start doing them in the plane. I think you will discover that
a couple of hours is all it will take to become proficient.
Michael
I agree.
Mike
MU-2
Correcting Poly-Brush mistake Craig Foster Home Built 31 November 23rd 03 01:55 PM
