Engine stumble, Any thoughts?
Old December 5th 05, 06:50 PM posted to rec.aviation.owning
Default Engine stumble, Any thoughts?
Roy Page wrote:
We have the same problem with two Archers and a 180.
The problem existed before and after overhaul of both 0-360 engines [1 by
Lycoming & 1 by Signature]
Both rebuilds had overhauled carbs fitted.
The other Archer with 2100 SMOH has the same stumble at or near 1500 RPM.
A clever guy on the net will soon enlighten us as to the cause I am sure ??
Until I saw the other suggestions, which sound better, I was going to
suggest checking the primer lock. Whenever I saw something like this
on a Warrior with an O-320, this turned out to be the case.
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
