My 172M doesn't have any stumble for some reason. It is the rpm range
generally less than 1500 rpm though, where the carb has to evolve from the idle jet system to the main jet. Carbs have a problem in this area because this transistion simply involves a gradual change of the jet system design, yet has to keep the mixture within a burnable range (about a 9:1 to 18:1 air/fuel ratio) or there will be a stumble. I don't know how carb designers (in the 30s I suppose) got it to work as well as they do. The main jet system is simple. The idle jet system is always a wierd collection of ports etc. Is it a lean stumble? or is it maybe a rich stumble? |
When closing the throttle, a lot of the fuel on the walls of the manifold
(and there is a LOT of fuel on the walls) will flash off. My guess is a rich stumble. But that's just a guess, eh? -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. "nrp" wrote in message oups.com... My 172M doesn't have any stumble for some reason. It is the rpm range generally less than 1500 rpm though, where the carb has to evolve from the idle jet system to the main jet. Carbs have a problem in this area because this transistion simply involves a gradual change of the jet system design, yet has to keep the mixture within a burnable range (about a 9:1 to 18:1 air/fuel ratio) or there will be a stumble. I don't know how carb designers (in the 30s I suppose) got it to work as well as they do. The main jet system is simple. The idle jet system is always a wierd collection of ports etc. Is it a lean stumble? or is it maybe a rich stumble? |
(and there is a LOT of fuel on the walls) will flash off. That's very true for a cold engine and especially with autofuel (which I use in the 172M). In this case he was using 100LL in a warm engine, so it wouldn't seem so likely. I have never heard before of the kind of stumble given by the OP. It could be a rich flash afterall. |
oups.com... When closing the throttle, a lot of the fuel on the walls of the manifold (and there is a LOT of fuel on the walls) will flash off. That's very true for a cold engine and especially with autofuel (which I use in the 172M). In this case he was using 100LL in a warm engine, so it wouldn't seem so likely. I have never heard before of the kind of stumble given by the OP. It could be a rich flash afterall. I think you would find it to be true for warm engines also. There is a good film of fuel on just about the whole surface of the intake manifold in just about any carbureted engine. -- Geoff the sea hawk at wow way d0t com remove spaces and make the obvious substitutions to reply by mail Spell checking is left as an excercise for the reader. |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
