"Doug" wrote in message
ups.com... The ability to land in rough water is limited by the hull strength. Yes, that too. But control on the water surface is at least as important as not breaking something. The hull design also affects the forces experienced; a shallow hull decelerates more quickly, transmitting higher forces to the airframe. Sheer strength is always a factor, of course...but that's true of every aspect of aircraft design. It's often not primary, and I disagree that it is here. Hulls intended for rough water operation are designed with a steeper "V". |
Yes, deep and sharp (highly angled) V's tend to cushion the landing
somewhat. Also helps if the are concave. On my plane and all the other pontoon type aircraft that I know of, the first thing that will break is a strut. The breakpoint varies, sometimes it's the vertical strut, sometimes the horizontal (on my plane it is known to be the vertical strut). The Lakes don't have struts and since the fuselage is also the hull, it IS stronger and can take more. But.... when Lakes breakup (there is a video), it is CATASTROPHIC, they really come apart. On my aiplane, usually if one strut breaks you can limp in to shore. If both front struts break, and the broken part doesn't settle on the fitting (they break at the lower fitting), you are hosed. You will go over frontwards, maybe not capsize, but the plane can no longer taxi, the prop cuts the floats etc. Bad scene. But sometimes the broken piece settles on the fitting and you can limp to shore even with 2 or more struts broken. The biggest problem is judging just how big and steep a wave you can land on, also depends on how close together they are. There isn't any helpful info in the POH, that I've ever seen. And it IS a problem. Especially with straight floats. They can't circle forever and have to go ahead and land. In this respect the amphib gives you the option of landing on land. So then pilots try and land close to shore to take advantage of the lee of the trees and run into the associated hazards of wind shear and landing close to shore, running into rocks etc. If those waves look too big, and if in doubt, don't. Pretty easy to break a strut. The hulls themselves seem to take it fine, seldom dent a hull from landing on a wave, at least not that I have heard of or seen. Probably possible though. You might just loosen rivets, I suspect. Landing on big swells in another matter altogether. I am talking about waves that you see on a typical lake, maybe one foot high and 20 to 75' apart. Ocean swells are MUCH further apart and can be much larger. But even the big planes made to land on the ocean, Grummans and the other Navy WWII one (can't remember its id), can get into waves and swells they can't handle. |
Doug wrote:
But even the big planes made to land on the ocean, Grummans and the other Navy WWII one (can't remember its id), can get into waves and swells they can't handle. Grumman, Martin, and Consolidated all made seaplanes for the Navy at that time. George Patterson Coffee is only a way of stealing time that should by rights belong to your slightly older self. |
FA: (One Day Left) - 6 BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Josh | Aviation Marketplace | 0 | November 13th 04 01:23 PM |
FA: 6 AVIATION FLYING BOOKS - FAR, AIM, IFR, AOPA, P-47, Seaplanes... | Nemo | Aviation Marketplace | 0 | November 7th 04 08:11 PM |
Question about Seaplanes | Sami | Aviation Marketplace | 11 | September 23rd 04 02:04 AM |
Jet Seaplanes??? | Roy Smith | General Aviation | 7 | August 23rd 04 11:29 AM |
Seaplanes and insurance | Robert M. Gary | Piloting | 1 | August 1st 03 05:55 PM |
