chris wrote:
snip You probably already know this but: if you go the RC way, be kind to the RC pilots and either stick to 27 mHz or avoid the aircraft-only frequencies. Boats and cars don't get written off by a bit of interference like aircraft do. There usually are no RC equipment near where I fly, and if there were I would have a problem too if they were on my frequency. I however am only transmitting for about 1/2 second for each photo so it it not a continuous broadcast. Shortening the antennas, on the receiver and transmitter on the sailplane units would also reduce interference risks for all users. It would also be interesting to know of the IR control systems used for indoor models work for this application or if they get swamped by sunlight reflected off the wings and fuselage. Tried that - some pictures work - but the sunlight is definitely a problem for many [but not all] angles. I got some good shots using a Canon Powershot G5 and it's IR remote, but a lot of shots failed because of the sun. I had built a glareshield that helped, but in the end that was too frustrating to everything lined up for an air to air shot and have no photo. Sorry to hear that! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Martin Gregorie wrote:
None of them have remote releases, unfortunately, but I think this can accomplished with some tinkering, using a low cost radio control system for model cars/aiplanes. You probably already know this but: if you go the RC way, be kind to the RC pilots and either stick to 27 mHz or avoid the aircraft-only frequencies. Boats and cars don't get written off by a bit of interference like aircraft do. Good thoughts - I was thinking of the cheapest car type with the shortest usable antenna on the transmitter, since only 30 feet of range is required. It would also be interesting to know of the IR control systems used for indoor models work for this application or if they get swamped by sunlight reflected off the wings and fuselage. I'm not aware of this type, but I suspect swamping wouldn't be a problem. IR units typically use modulation to avoid ambient light level problems. Do you have a URL or two I could look at? -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
Martin Gregorie wrote: It would also be interesting to know of the IR control systems used for indoor models work for this application or if they get swamped by sunlight reflected off the wings and fuselage. I'm not aware of this type, but I suspect swamping wouldn't be a problem. IR units typically use modulation to avoid ambient light level problems. Do you have a URL or two I could look at? Sorry, no tried and tested URLs. I'm a Free Flight model flier not an RC pilot but I read the mags and use the servos as output from Free Flight models automatic systems. Asking your local RC club if any of them use IR systems and talking to them if they do would probably be more useful than reading web adverts. This way you'll find out what works and what doesn't and crucially, what's available and well regarded in your area. Having said that, I did a quick Google for "indoor IR control models". http://n-lemma.com/indoorrc/ was the first hit. Cool pics, and there are links to equipment lists at the bottom of the page. Who knows, you might even get into this stuff as a winter activity. The links on this site may help too: http://members.aol.com/Lecisifly/ztron.html You need a receiver that can drive a standard servo. This will be easier to rig to trip the camera release: the very light weight stuff uses specialized, very small low powered control actuators and servos. Not what you want. By "standard" servos I mean an off the shelf model shop item with a three wire connection: they all accept the same signals and voltage and, apart from the connectors used by different receivers, are interchangeable. These range from small (20mm x 15mm x 7mm, 7g) upwards and generate more oomph as they get bigger. The very small and cute start to get expensive, but the "mini" and "standard" sizes are fairly cheap: in the $20-$30 range per servo. Take care to design your triggering mechanics so you can't stall a servo or drive it into a limit stop: they don't like that at all. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
For a video camera option instead of a still camera I saw this and
thought it might be good for head mounting, as well as easy to mount externally on wingtip, or tail. Tony Hawk First Video Camera http://www.tigerdirect.com/applicati...&Sku=P303-1000 it has an SD card, and I think 32mb=~30 minutes. so a 1GB card would probably be a long video. if it works that way. Chris |
Refinish a Glider in Europe | Jim Culp | Soaring | 4 | November 19th 05 08:21 PM |
Aerodynamics of carrying water | Gene Whitt | Soaring | 54 | October 19th 05 07:24 PM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
