T o d d P a t t i s t wrote:
"Wayne Paul" wrote: Check CB radio shops or search Froogle for "SWR meter" for dozens under $50. The standard CB SWR meter's range is 2 to 30 MHz. For accurate measurements you need one designed for VHF frequencies. It's worthwhile comparing the measurements you get with the two, which is what I did when I bought my CB-intended SWR meter. (Used a Bird for the comparison) The numbers were within 0.1 of each other over the entire aircraft band. Of course, I bought my Radio Shack meter 10 years ago, so the design may have changed. If anyone has a good VHF SWR meter and wants to report a comparison with a current Radio Shack (or other) model, it would be a valuable piece of information. I did the same comparison (also using a Bird instrument - shouldn't every glider pilot have a Bird in his tool box?) with a 25 year old Radio Shack model, and got the same results. Wayne and I discussed the issue, and concluded that the CB units are probably just fine for SWR measurements, so use it if you have one. The reason is SWR measurements are ratio measurements, so frequency effects tend to cancel. Not so if you want to do power measurements, for example. Wayne suggested (and I agree) that if you are going to buy one, spend the extra $10 and get one for our frequencies. Here are couple we think would do the job, but we haven't actually used either of them: http://www.thomas-distributing.com/meters-konnex1.htm http://www.mfjenterprises.com/produc...rodid=MFJ-812B (the $29 unit) -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
magneto installation help | Dick | Home Built | 5 | February 10th 05 03:02 PM |
Skycraft Landing Light Installation Pix | Jay Honeck | Owning | 5 | February 6th 05 02:05 PM |
Great deals on avionics installation kits and tools | Randy Cooper | Aviation Marketplace | 0 | January 14th 05 04:07 AM |
Equipment Installation | Stan Prevost | Owning | 0 | November 16th 04 05:28 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
