In article .com,
"Flyingmonk" wrote: The CH-7's blades were better, they didn't bow like a banana. The were bowing forward as you go farther from the root of the blades. This changed the pivot point for the baldes, imagine taking a straight bladed sword and rotating it, the tip and the rest of the sword stays at the pivot point. Now imagine taking a curved sword and rotating it the same way, you'll notice that the tip stays at the pivot point, but the remainder of the sword will rise or fall due to the curve. The CH-7's blades were fabricated better, they were more uniform or should I say more consistent than what Denise was able to produce. Being more uniform, and of the shape that they were designed, they were easier to track and balance. This resulted in a smoother flying ship. Denise couldn't get the blades to come out as designed. They were not consistent they bowed where they shouldn't have and all this resulted in problems when trying to track and balance the blades. I remember that Gill had a hard time getting the baldes to fly smoothly. I think this fact alone(bad blades) resulted in inefficient rotor system, Unlike propellers, the blades of a helicopter changes pitch continously, this resulted in "shaking" or unsmooth helicopter. The shaking caused the frames to crack! Again, instead of addressing the problem (bad blades), Denise added more metal to the frame in an attempt to beef up the area prone to cracking. Since the blades were not as efficient as the CH-7's blades, the engine had to work much harder to get the same lift. That's where Denise came up with the bandaid fix again, the PEP kit. Instead of tackling the blade problem, he overworked the engine by PEPing it up. CH-7s didn't need to be PEPed up. That's my two cents worth. Sir, I hope you will not feel singled out by me, but how does abusing the man's name lend credibility to what appears to be a reasonably scholarly hypothesis? This is only one example of what I mean when I say I don't give much credence to either Mr. Fetters or his detractors. Sarcasm, rudeness, disrespect, arrogance, snottiness, and all the other exhibits of hostility that permeate both sides of this discussion - and so many others here - may bring self-righteous snickers to the like-minded, but do *nothing* to persuade your opponents or the neutral lurkers. |
Smitty Two wrote:
Sir, I hope you will not feel singled out by me, but how does abusing the man's name lend credibility to what appears to be a reasonably scholarly hypothesis? This is only one example of what I mean when I say I don't give much credence to either Mr. Fetters or his detractors. Sarcasm, rudeness, disrespect, arrogance, snottiness, and all the other exhibits of hostility that permeate both sides of this discussion - and so many others here - may bring self-righteous snickers to the like-minded, but do *nothing* to persuade your opponents or the neutral lurkers. Fetters is one of very very few people that makes my blood boil. Normally I'm a very docile person. I lost a friend, Gil Armbruster, An FAA executive with 10s of thousands of hours of flight time, in the mini500. Gil was a metoculous builder. Fetters is blamed his accident on pilot error. Which is correct, Gil's accident was due to pilot error, his error was choosing the mini500. |
Flyingmonk wrote:
Fetters is one of very very few people that makes my blood boil. Normally I'm a very docile person. I lost a friend, Gil Armbruster, An FAA executive with 10s of thousands of hours of flight time, in the mini500. Gil was a metoculous builder. Fetters is blamed his accident on pilot error. Which is correct, Gil's accident was due to pilot error, his error was choosing the mini500. Gil had around 200 hours in the Mini, which seems to be its life limit for airframe and pilot... |
Darrel Toepfer wrote:
Gil had around 200 hours in the Mini, which seems to be its life limit for airframe and pilot... Thank you for the correction Darrel. It was a typo, I meant write: FAA executive with 10s of thousands of hours of flight time, and almost 200 hrs in the mini500. |
Flyingmonk wrote:
Thank you for the correction Darrel. It was a typo, I meant write: FAA executive with 10s of thousands of hours of flight time, and almost 200 hrs in the mini500. I understood ya, just didn't want anyone else to be confused... |
![]() "Darrel Toepfer" wrote I understood ya, just didn't want anyone else to be confused... chuckle I didn't even catch it. It would be truly remarkable if anyone had tens of thousands in a Mini. Supernatural, shall we say? g -- Jim in NC |
Morgans wrote:
chuckle I didn't even catch it. It would be truly remarkable if anyone had tens of thousands in a Mini. Supernatural, shall we say? g That was the only phunnie part of this whole thing... I'd say if we weren't here to say otherwise, bFetters would have the numbers in Zzzzoom proportions... |
Mini500's blades were bowing forward as you go from the root to tip. This changed the pivot point for the baldes, imagine taking a straight bladed sword and rotating it, the tip and the rest of the sword pivots at the pivot point. Now imagine taking a curved sword and rotating it the same way, you'll notice that the tip stays at the pivot point as well as the root, but the remainder of the sword will rise or fall due to the curve. The CH-7's blades were fabricated better, they were more uniform or should I say more consistent than what Fetters was able to produce. Being more uniform, and of the shape that they were designed, they were easier to track and balance. This resulted in a smoother flying ship. Fetters couldn't get the blades to come out as designed. They were not consistent, they bowed where they shouldn't have and this resulted in problems when trying to track and balance the blades. I remember that Gill had a hard time getting the baldes to fly smoothly. I think this fact alone (bad blades) resulted in inefficient rotor system, Unlike propellers, the blades of a helicopter changes pitch continously, with bad blades, this resulted in "shaking" or unsmooth helicopter. The shaking caused the frames to crack! Again, instead of addressing the problem (bad blades), Fetters added more metal to the frame in an attempt to beef up the area prone to cracking. Since the blades were not as efficient as the CH-7's blades, the engine had to work much harder to get the same lift. That's where Fetters came up with the bandaid fix, the PEP kit. Instead of tackling the blade problem, he overworked the engine by PEPing it up. CH-7s didn't need to be PEPed up. That's my two cents worth. |
Smitty Two wrote:
Sir, I hope you will not feel singled out by me, but how does abusing the man's name lend credibility to what appears to be a reasonably scholarly hypothesis? This is only one example of what I mean when I say I don't give much credence to either Mr. Fetters or his detractors. Sarcasm, rudeness, disrespect, arrogance, snottiness, and all the other exhibits of hostility that permeate both sides of this discussion - and so many others here - may bring self-righteous snickers to the like-minded, but do *nothing* to persuade your opponents or the neutral lurkers. First of all, I want to thank you for pointing that out. You are correct, I have rewritten it: Cicarre's CH-7's blades were better, they didn't bow like a banana. The Mini500's blades were bowing forward as you go from the root to tip. This changed the pivot point for the baldes, imagine taking a straight bladed sword and rotating it, the tip and the rest of the sword pivots at the pivot point. Now imagine taking a curved sword and rotating it the same way, you'll notice that the tip stays at the pivot point as well as the root, but the remainder of the sword will rise or fall due to the curve. The CH-7's blades were fabricated better, they were more uniform or should I say more consistent than what Fetters was able to produce. Being more uniform, and of the shape that they were designed, they were easier to track and balance. This resulted in a smoother flying ship. Fetters couldn't get the blades to come out as designed. They were not consistent, they bowed where they shouldn't have and this resulted in problems when trying to track and balance the blades. I remember that Gill had a hard time getting the baldes to fly smoothly. I think this fact alone (bad blades) resulted in inefficient rotor system, unlike propellers, the blades of a helicopter changes pitch continously as it goes around the vertical shaft, with bad blades, this resulted in "shaking" or unsmooth helicopter. The shaking caused the frames to crack! Again, instead of addressing the problem (bad blades), Fetters added more metal to the frame in an attempt to beef up the area prone to cracking. Since the blades were not as efficient as the CH-7's blades, the engine had to work much harder to get the same lift. That's where Fetters came up with the bandaid fix, the PEP kit. Instead of tackling the blade problem, he overworked the engine by PEPing it up. CH-7s didn't need to be PEPed up. That's my two cents worth. |
In addition, Glen Ryerson, who built and flown the CH-7 "Miss Nina" in
PA, didn't have any trouble tracking and balancing his blades. |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
