![]() "stol" wrote in message oups.com... ///////////////////////////////////////// Look close at the Lyc / Cont cranks and you will see balance marks on the rod throw end. As you have pointed out they don't have counter weights so thats the only logical place to correct a large imbalance that happens during the crank forging process. Yes, you have noticed the factory and aftermarket balance marks. Have you ever checked the depth of material removed? How deep is the nitride layer usually? What do you do about the bifilar dampers that most higher horsepower crankshafts have? It is a misnomer that these are commonly called crank counterweights. You install new bushings and rollers? Do you balance with them installed on the crank? What about a Lycoming ring gear? btw, thanks for your three reply posts for "setting me straight". Kent Felkins Felkins Aircraft Ltd. FAA CRS WNKR918K Tulsa Oklahoma |
Kent Felkins
Felkins Aircraft Ltd. FAA CRS WNKR918K Tulsa Oklahoma ///////////////////////////////////////// I was just giving out my two cents worth. After all this is the Rec, Aviation, " HOMEBUILT" site. I would never post something like this on the rec. aviation "certified" site. After all the FAA knows all.I still think Lycoming murdered 13 people by selling a inferior product and the FAA was in bed with them the whole way. I have owed several certifeis planes in my life and I never want to see a yellow tag again. Those things have tried to kill me a couple of times and the funny thing is the Feds didnt even investigate the repair stations involved. Now I will head at and fly my homebuilt plane powered by a Firewall forward I designed and built. The air is good and thick at -34f. Peace and Merry Christmas from Jackson Hole Wy Ben www.haaspowerair.com |
Pocket PC Weight and Balance Spreadsheet | Navzilla Support | Piloting | 0 | October 9th 05 11:47 PM |
Cessna 172 F Weight and Balance | [email protected] | Owning | 8 | September 22nd 05 02:38 AM |
crankshaft counterweights | Dave Butler | Owning | 10 | February 10th 05 04:08 PM |
Wierd vibration -- Prop or engine, balance or not??? | Chuck | Owning | 17 | December 1st 04 02:12 PM |
Grob102 elevator balance mods | OscarCVox | Soaring | 0 | April 1st 04 11:32 PM |
